E30 Stalls out in gear... - BMW Forum - BimmerWerkz.com
Old 01-06-2009, 02:44 PM   #1 (permalink)
Jedz123's Avatar
Car: 1986 BMW 325e
Jedz123 is on a distinguished road
Send a message via AIM to Jedz123
Hey guys just replaced the starter in my 86 325e... Well I'm very happy with the new starter it gets my car up and running every time! But now after going on it's first run after the starter fix the car will fall on it's self as soon as the clutch is released. The car will rev up fine then it will die when the clutch engages completely. This is also intermittent so the car will drive fine then the car will just stop accelerating, the motor will die and stall then I push the clutch in and then the car will idle but refuse to do anything else... Not to impressed for it ran fine before I replaced the starter. I had to remove the Mass air flow meter the plumbing hooked to it, plus the air box and the throttle body and all the plumbing hooked to that to get the damn starter out...(Write up coming soon)
Any ideas guys? Thanks
-Jedz
MY Cars:
1986 BMW 325e
1990 Mazda Miata MX-5
My Bike:
1981 Honda C70 Passport
MY Passion:
Anything with an internal combustion engine.
Jedz123 is offline   Reply With Quote
Old 01-06-2009, 02:52 PM   #2 (permalink)
Maybe you need to look at how all those intake parts came back together.
Old 01-06-2009, 03:46 PM   #3 (permalink)
Jedz123's Avatar
Car: 1986 BMW 325e
The problem is fixed!
I did as you recommended and did a double check on my intake plenum and vacuum lines. I found 3 significant leaks caused by rotted vacuum lines. Replaced the lines and the car runs great now!
MY Cars:
1986 BMW 325e
My Bike:
MY Passion:
Old 01-06-2009, 03:48 PM   #4 (permalink)
Sweet!!
Matching Gear Shift & Emergency brake Boot(s) E30 E36 318 325 customshiftboot Aftermarket Parts 2 01-17-2007 05:48 AM
NEW! Matching Gear Shift & Emergency brake Boot(s) E30 E36 318 325 customshiftboot Aftermarket Parts 0 09-12-2006 01:37 PM
NEW! Matching Gear Shift & Emergency brake Boot(s) E30 E36 318 325 customshiftboot Aftermarket Parts 0 07-31-2006 03:46 PM
Gear Ratios On E30 325i alfamitch 3-Series (E21, E30) 3 10-05-2004 09:57 PM
E30 u shift into gear and it doesnt go any know y? italian_stud02 3-Series (E21, E30) 8 12-12-2003 02:47 PM
