E30 Lsd - BMW Forum - BimmerWerkz.com
Old 03-09-2005, 04:15 PM   #1 (permalink)
e30rig is an unknown quantity at this point
I was wondering if there is a way of telling if a diff is a lsd by looking at the serial number and what type it would be
e30rig is offline   Reply With Quote
Old 03-09-2005, 04:37 PM   #2 (permalink)
german-speed-demon's Avatar
eurotuner just had a project up. They said their should be an "s" stamped on the case. If there is, that should be Limited Slip. Also, jack the ass end up and turn one wheel. If the other turns the other way, it's LS. I think...i'll check and try to post tommorrow.
R.I.P fast 6
Old 03-09-2005, 10:02 PM   #3 (permalink)
Kowalski's Avatar
should say on the diff tag before the numbers. there wil lbe an S or you could phone the dealer and give them your id tag and they will tell you, but they might screw up ghead
264* roatation and 388 lift
Old 03-10-2005, 11:21 AM   #4 (permalink)
longpole938 is an unknown quantity at this point
if rotates the same way its LSD.... opposite is open.
just make sure both wheels are in the air, its really bad for an LSD to turn one wheel and not the other
longpole938 is offline   Reply With Quote
Old 03-10-2005, 12:12 PM   #5 (permalink)
Kowalski's Avatar
[snapback]307972[/snapback]
how is that bad? it does it every time you turn a corner.... one wheel will spin more then the other one, which in theory should be the same as holding one and spinning it a little bit should it not? no offence or anything
Old 03-10-2005, 02:52 PM   #6 (permalink)
i dont know if that is too bad for it, but yes the rear wheels should spin in the same direction when one is spun in order for it to be a LSD. what kind of car is this to make you think it has an LSD?
Old 03-15-2005, 05:50 PM   #7 (permalink)
i jacked it up when i got it when i spun one wheel the other spun same direction but only when only turned really slow so i wasnt sure was it limo or not so of course i tryed to throw it round it done a few doughnats but now it only spins one wheel.thanks for the help lads now im fairly sure its a limo it will be worth it to strip it done prob needs plates would anyone know how much they would cost out of interest ?
Wanted: E30 - 325iX benny1856 Looking For 0 10-29-2005 10:43 AM
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 04:27 PM
what bmw model year is the most reliable and least problematic for the e30? träumer 3-Series (E21, E30) 4 09-14-2005 07:12 PM
1990 E30 V belt picture/diagram/info sought snpower 3-Series (E21, E30) 5 09-10-2005 07:07 PM
