E30 intermittent clutch problem - BMW Forum - BimmerWerkz.com
Old 06-17-2004, 03:29 AM   #1 (permalink)
chopper is an unknown quantity at this point
Hi All
I'd be extremely grateful for any suggestions:
I have a 316i E30 and over the last couple of months I have noticed an intermittent clutch problem, it will work fine but then one time every 50ish when I want to change gear there is almost no resistence when I depress the clutch but then I let the peddle up depress it again and it works perfectly fine!!
I checked the fluids and they seem ok, has anybody else had the same problem or can offer any soulutions?
chopper is offline   Reply With Quote
Old 06-20-2004, 03:25 PM   #2 (permalink)
will1506 is an unknown quantity at this point
Send a message via ICQ to will1506 Send a message via AIM to will1506 Send a message via MSN to will1506 Send a message via Yahoo to will1506
make sure there's no leaks and that your brake fluid is topped up because BMW cluthes run off brake fuilds. Try bleeding the system. Also make sure that there's no leak where the master cylinder is. If the bleed doens't work, I think either your master or slave cylinder is going. I had to replace mine not too long ago.
will1506 is offline   Reply With Quote
Old 06-22-2004, 10:39 AM   #3 (permalink)
xxg00chxx's Avatar
xxg00chxx is an unknown quantity at this point
i know it sounds stupid, but because the issue is so intermittant, i would check the knee bolster under the dash. mine has sort of 'grabbed on' to my clutch before, making it feel as though there was no return force in the clutch. i fixed the issue by simply re-adjusting the bolster.
if you don't know what i am referring to, it's the crappy piece of thin fiberboard composite bullshit that BMW seemed compelled to put below the steering column on our cars. it used to piss me off that this part seemed so cheap and cheesy, until i found out that it is meant to break easily in case of front impact crash. i guess it's better that breaks than your knees...
g00ch
'88 325i cabrio
<a href='http://www.sicracing.com' target='_blank'><img src='http://members.cox.net/aaron.gochee/images/mycar/p4050007small.jpg' border='0' alt='user posted image' /></a>
xxg00chxx is offline   Reply With Quote
Is This A Clutch Problem? frank3 3-Series (E36) 18 05-15-2012 12:01 AM
Clutch Problem Possibly? Saukk 3-Series (E46, E90) 7 08-27-2005 05:30 PM
a possible clutch problem? Furious 3-Series (E36) 6 12-20-2003 02:37 AM
1983 325E clutch problem will1506 3-Series (E21, E30) 2 08-05-2003 02:12 PM
