E30 Idles, Sputters Then Dies - BMW Forum - BimmerWerkz.com
Old 06-13-2005, 01:59 PM   #1 (permalink)
moetinger is an unknown quantity at this point
My 90 e30 has been acting up again. This time the engine light's coming on. When I am at stoplights the engine will chug a little then die on me. When I try to accelerate it sputters a lot then barely goes. I looked for the obvious--vacuum leaks etc. and found nothing. I've had the timing belt, fuel pump/filter and full tune up done w/in 3K miles.
Car revs great when in neutral. The problem seems to have gotten progressively worse.
Just wanting to get an idea of what the prob could be before I take it to the import repair shop and get molested.
Thanks!
moetinger is offline   Reply With Quote
Old 06-13-2005, 06:16 PM   #2 (permalink)
Have you had the ignition system checked?
Old 06-14-2005, 07:46 AM   #3 (permalink)
yeah i've had the plugs, cap, wires and rotor changed in the tune-up if that's what you are asking.
Old 06-14-2005, 02:03 PM   #4 (permalink)
e36_m3_Turbo's Avatar
my friends is somewhat like that when goimng back to idle. but dosnet die all the time.i was thinkin it was the valves, they sometimes need to be adjusted. which i heard.
No longer red.
Old 06-14-2005, 03:20 PM   #5 (permalink)
what makes me think that it is electrical is that the car will run fine for a few then it seems like the engine cuts out and the engine light pops on for a sec. Who knows. I am going to bit the bullet and let the dealer look at it.
Old 06-15-2005, 08:41 PM   #6 (permalink)
offabroadway is an unknown quantity at this point
You said that in neutral, the car idles/revs fine? I'm going to assume that this is an automatic transmission E30? Your lockup clutch or other transmission clutches might be catching or worn/stuck. That might be something to look at. If it is an auto, when was the last time she was flushed and refilled? Just a few shots in the dark, hope they help.
If the engine lurches, dies, and catches again, the sudden drop in revs can trigger the oil pressure/engine warning light, which will stay on until you turn it off and restart it.
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 06-15-2005, 09:52 PM   #7 (permalink)
Kowalski's Avatar
since your engine light comes on im going to assuming that it would be the air fuel mixture causing the light to come on, so it could be a poorly adjusted AFM sounds exactly the same as the problem i had. also could be a multitude of other things... fuel presure, ignition, the list goes on... if you could get an engine code off it that would be awsome.
264* roatation and 388 lift
Old 04-03-2008, 03:07 PM   #8 (permalink)
Diotima's Avatar
Car: 2002 Mazda Mx-5, 1989 320i
Diotima has a spectacular aura aboutDiotima has a spectacular aura about
Send a message via MSN to Diotima Send a message via Yahoo to Diotima Send a message via Skype™ to Diotima
Me too
soz to bump up an old thread, but having similar probs with my 320i 1989 auto, its fine in park but when idle in drive the rev counter is up and down, sometimes dropping so low it cuts out, its started to shudder in idle and drag on acceleration now......stinking like its flooding....any ideas?
Diotima is offline   Reply With Quote
Old 04-07-2008, 12:32 AM   #9 (permalink)
Jonesz0003's Avatar
Car: 1991 BMW IS, 5 speed
Jonesz0003 is on a distinguished road
Send a message via AIM to Jonesz0003 Send a message via MSN to Jonesz0003 Send a message via Yahoo to Jonesz0003
I am having the same problem with my 91 318is but it is a stick and not an auto. I had to replace the engine when i bought it so i changed the plugs so i would guess thats not it and will be running test and stuff at the shop i work at tomorrow so if ppl have more ideas shoot them this way lol and i will do the same if i fing ne thing and thanks already those are some good ideas to check out first so thanks
Jonesz0003 is offline   Reply With Quote
Old 06-08-2008, 02:24 AM   #10 (permalink)
peterdix is on a distinguished road
Did you get to the bottom of your problem
Daughter has a 1993 - 318, has had a bit of a hunt at idle for past year, since she brought it. today it started ti misfire and then cut out. restarts straight away but often misfires again. any advice before getting to a diagnostice shop would be helpful
peterdix is offline   Reply With Quote
Old 06-08-2008, 10:12 AM   #11 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
when was last tune-up?
hunt at idle is usually attributed to leaks in your intake, an AFM problem(maybe just dirty), or idle control valve not doing it's job right.
Old 06-08-2008, 05:32 PM   #12 (permalink)
Diotima's Avatar
Mine was ICV - took 3 trips to garage to get it right, but now all is good
If you don't know where you are going, any road can take you there
Old 06-08-2008, 08:01 PM   #13 (permalink)
Lightbulb
Thanks!
how was condition of fuel filter when u changed?... dirty? if yes, suspect clogged injectors. OR,
defective CAT. Partially clogged CAT converters that in effect restrict exhaust flow will cause the symptoms you complain of.
whats up with my e30 it shakes like a diesel at idle? träumer 3-Series (E21, E30) 8 10-14-2005 10:32 PM
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 04:27 PM
starts then dies....very rough low idle help!! pagz 5-Series (E12,E28, E34, E39, E60) 5 07-09-2004 02:04 PM
