My 87 325is needs a new gas tank, the stock tank is 14 gallons, the 88 and newer e30's
use a 16 gallon tank. I would prefer the larger tank and im just wondering if this swap can be done.
I dont know about the swap, but my 88 has a 14 gallon tank. So, maybe the changeover was a mid year change, if so be careful about an 88 as a donor for the bigger tank.
Originally posted by Abdul@Feb 11 2005, 11:03 PM I dont know about the swap, but my 88 has a 14 gallon tank. So, maybe the changeover was a mid year change, if so be careful about an 88 as a donor for the bigger tank.
[snapback]290240[/snapback]
take some measurments once you pull out the other one if the bolting paterns are the same or you can make them the same but the other one just hangs a bit lower then your fine, but it might be wider in which case it probably wont fit into the spot, so take measurments and then find one and measure it and if you'v got a little room to play with then go for it.
__________________ M42 Custom ground cams for sale PM me
264* roatation and 388 lift
i have a brand new aftermarket tank that i will be pulling off in the next few weeks. it has about 300 miles on it so far. i'm switching over to a fuel cell. my car was made in 09/87, so if the tank will fit. i'm willing to get rid of both senders and the pump assembly with it. the pump is on its way out though.
the later model tank is way different, the ventilation is different and it has in-tank pumps instead of an external pump. You can make it work but you would have to have a whole later model car with all of the parts in it
