E30 Engine Stalling During A Left Turn - BMW Forum - BimmerWerkz.com
Old 10-09-2004, 11:56 AM   #1 (permalink)
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
Hi, i was wondering if anyone knows what is causing my engine to stall out during a left turn while the gas is on. I have a 1987 E30 2.5L 6. Thanks in advance. Hank
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline   Reply With Quote
Old 10-11-2004, 01:34 AM   #2 (permalink)
theratdude64's Avatar
theratdude64 is an unknown quantity at this point
Send a message via AIM to theratdude64 Send a message via MSN to theratdude64
closest thing I can think of is a fuel sloshing or something problem... hard left or any left turn?
<img src='http://s89706284.onlinehome.us/bmwsig.jpg' border='0' alt='user posted image' />
82 320i 1.8 liter Automatic
86 Camaro 5 Speed
member of the wonders WTF is up with everyone being a member of sigs
member of the beasty engine club
member of the manual tranny club
member of the Utah Sucks Club
member of the V8 OWNS JOO Club
theratdude64 is offline   Reply With Quote
Old 10-11-2004, 02:18 PM   #3 (permalink)
RedlinedRU's Avatar
usally if its more then an 1/8th of a turn it will cut off, and recently it doesnt need to accelerate to cut off.
Old 10-12-2004, 08:25 AM   #4 (permalink)
jinkly is an unknown quantity at this point
[snapback]209387[/snapback]
this is probably a problem of the fuel tank. In some european cars, as Renautl Clio, have this problem. Tha differents straight lines that the fuel has on his bottom could be broken. Clean your fuel tank dissambled and pay atention on the bottom or the differents compartiments that it has.
Regards.
jinkly is offline   Reply With Quote
Old 10-13-2004, 01:40 AM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
If it sputters then dies it's a fuel problem. But if it dies like you turned the key off and doesn't sputter I suspect an eletrical problem. My E30 had that sort of problem, it just completly die like I turned the car off. I installed a new DME relay, aka main relay and haven't had a problem since. This is a cheep part and if it doesn't fix your problem you probably won't ever need to replace that relay again since the one in my car was orignial from '88 so they last a long time. Also check the wires that go into your 2 fuel pump relays and main relay, one my be loose. This is how I found my main relay to be bad. While the car was running I tapped on the relays, everytime I tapped the main relay the car died.
My M50 Powered E30 Page
Left turn indicator light (on Dash) dead {|nf3rn0} 3-Series (E36) 6 01-26-2004 02:20 AM
HELP! - Engine/Tranny Vibration & Engine Light Fangs 3-Series (E46, E90) 10 01-24-2004 07:30 PM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
