E30 Engine Questions - BMW Forum - BimmerWerkz.com
Old 09-22-2004, 06:00 PM   #1 (permalink)
Jimmy Clitheroe is an unknown quantity at this point
I just bought my first 3 Series. It's a white '89 E30 325i automatic with 115K on the odo (it's a California car, if that's any help). It runs great, but here are a few observations I'd like your help on. Thanks.
1. The white paint in the engine bay is discolored with a yellow film. It's pretty baked on, so I presume it's burnt oil vapor. Which brings me to my next points...
2. The hot engine smells of burnt oil.
3. There's a lot of black oil crud on the baffles between the bottom of the head and the exhaust manifold.
Do these point to an oil leak or gasket problem? Or is it something that you just have to live with on a car of this age? (I drove an MG for a month with a broken throttle cable, so dealing is something I can live with.)
4. The tachometer, MPG guage, and temperature guage don't work. I think it's just the fuses, where can I get a fuse box diagram?
5. Where can I get an original drivers manual?
6. How much should it cost to replace the timing belt in California? (I have no idea when it was last done, so don't want to risk putting on too many miles driving around in ignorance.)
7. Can I get a generic replacement windshield, or should I stick to genuine BMW parts?
If you've got any answers, I'd really appreciate your help. If you need more info, I'll try and get it.
Jimmy Clitheroe is offline   Reply With Quote
Old 09-22-2004, 10:29 PM   #2 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
*I believe that is just a coating of petrolium they use to prevent rusting in salty storage, sometimes they dont remove it and it cakes on.
* If it smells like burnt oil that means its most likely dripping on the headers.
That would have to leak through the Valve Cover Gasket. Common leak.
* They start black and then accumulate dirt, the dirt is then baked on. You can wash the crud off.
* First off clean out your engine bay. Get rid of any oil marks or streaks, this way you can see where a leak might be coming from. Then go ahead and tighten the nuts on the valve cover. I believe there are TWELVE 7mm nuts.
* This is a fuse. I believe its number 12 or 15.. dont remember
* Ebay
* Around $300 i think.
Fox is offline   Reply With Quote
Old 09-22-2004, 11:33 PM   #3 (permalink)
* Ebay
[snapback]197227[/snapback]
Thanks, that's awesome help.
Old 09-22-2004, 11:52 PM   #4 (permalink)
Nihilator is an unknown quantity at this point
It's called cosmoline; search the forums to find ways to remove it. I think Brake-Kleen is mentioned.
Don't forget to get a new valve cover gasket.
--Chris
<img src='http://www.tinsmithtech.com/graphics/sigpic.JPG' border='0' alt='user posted image' />
Dad's 1992 325iC
Nihilator is offline   Reply With Quote
Old 09-25-2004, 04:11 PM   #5 (permalink)
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
Originally posted by Nihilator+Sep 22 2004, 11:52 PM--><div class='quotetop'>QUOTE(Nihilator @ Sep 22 2004, 11:52 PM)</div><div class='quotemain'><!--QuoteBegin-Jimmy Clitheroe@Sep 22 2004, 10:33 PM
--Chris
[snapback]197310[/snapback]
[/b][/quote]
Brake-Kleen will work, so will some other things.
Check out this thread for more discussion - http://www.e30tech.com/forum/viewtopic.php...light=cosmoline
<a href='http://www.e30tech.com/forum/viewtopic.php?t=8854' target='_blank'><img src='http://www.e30tech.com/pictures/e30/sig25.jpg' border='0' alt='user posted image' /></a>
detour54 is offline   Reply With Quote
Newbie question(s) on engine maintenance Morgenster 3-Series (E21, E30) 9 12-19-2005 08:32 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
