My first post from way over in Melbourne, Australia.
I have recently bought a mint 325iS and considering some power upgrades. As the title goes, how hard and expensive is it to increase power output to 300bhp(without NOS)?
To do this,I would assume an M50 conversion would be the sensible thing to do first. After that Im not sure. I would have thought I would have some time to work on the engine as it will be outside the car.
Im thinking turbo would be the way to go. How reliable are these M50 engines for this kind of power, rods, pistons, bottem end? Im guessing I would need engine managment, strengthened gearbox, driveshafts and an LSD?
What about the engine bay, with the M50 engine, is there adequate room for a turbo and FMIC?
Thanks for your help guys!
Feel free to slate my suggestions above, the BMW world is pretty new to me.
ya dude you can get 300bhp without NOS easily. if you have the money, which it sounds like you do if you just got the car and your already plannng a M50 conversion. and ya dude i dont know from experience but i believe i have come acrouse a M50 conversion with the added turbo so you should have enough room. good luck with it man and pray that i get some money soon so i can do the same
You're new, so I'll forgive you this once, but if you say NOS again I'm going to smack you so hard your teeth will all move over one space to the right.
Addicted to Speed Since 1997 Founding member of the GreenDragon Poo Flingers Club
well so is superchargers and turbochargers esentially then, they all do the same thing, move more oxygen to the combustion chamber
Thats a fair point although I think the said substance (not mentioning the word for fear of teeth realignment!) is a little more volatile, not to mention the ongoing expenses of enthusiastic use.....
huh, i have used it on almost all of my cars, some more than others with no problems ever. the problem with nitrous is the pooor kits and improper installs. With a good ZEX or NX wet setup, properly installed you shouldnt see many problems at all with nitrous....only problems i have had with it is breaking clutches and axles
karmatik...when you specified 300bhp in your 325is...i'd figure you meant the car specifically meaning the m20 in there...obviously engine swaps can answer your problem almsot in 2 moves...
If you're looking to get 300 hp just buy the S50 and do a few simple mods to it. Then you have the stock reliability and don't have to fook with the car.
__________________ Finally pulled the M50 from the donor car.
M50 + S52 Cams + Mild Turbo Setup w/ Fmic, should be good to go. Then, feel free to do more to the M50, internally. Talk to Kyle(gotKraut) about that, or Alex320i.
__________________ I hate: people who haven't died yet that I hate. L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc. 2000 BMW M Coupe - Dakar-II - S52 "You gotta fix the nut behind the wheel before you fix the bolts on the car"
First off NOS is a brand, and second if you had spent any time with someone who knew what they were doing you would see that a nitrous kit is an easy way to get power when set up properly. The people that have problems with a N2O kit are the people that cheep out on it and don't install the proper safety devices like a WOT switch along with a RPM window switch. You also have to know the limits of your cars engine. You can't just throw a 150 dry shot on a car and expect it to work right. If I had a second car I'd throw a Nitrous Express kit on my M50. To do it right I'd spend around $700 and have an instant 100+ HP at the flip of a switch.
Now to the orginal poster, if you want 300+ HP you are going to have to spend some $$$$. A VANOS M50 with the AA supercharger kit with about 8 PSI will put down around 280 HP at the wheels. The SC kit alone is $4000+.
