e30 325is engine clicking noise - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 04-02-2004, 05:02 PM Thread Starter
mrpauly is an unknown quantity at this point
I have an e30 325is which has done 110k. I recently serviced the engine and replaced the timing belt tensioner and all the belts. The engine still makes this clicking sound which seems to be coming from the valve/tappet area. My mechanic says that these cars are naturally noisy but the noise wasn't this loud before. Does anybody have any suggestions?
mrpauly is offline
post #2 of 12 (permalink) Old 04-02-2004, 05:38 PM
Fox
Moderator
how rapid is the clicking?
Fox is offline
post #3 of 12 (permalink) Old 04-03-2004, 03:12 AM
Locating a noise is just a tool away.
You can buy a stethoscope.
Or use a mechanics stethoscope:
A long screw driver and place the handle against your ear.
Remember to stay clear of moving parts and electrical connections.
Use the metal tip to locate the loudest location and then we can suggest the fix.
These BMW engines are a lot of things, but noisey is not one of them.
My WAG, Wild Assumed Guess, is a worn injector.
Later,
&lt;img src=&quot;
KC Ron Carter is offline
post #4 of 12 (permalink) Old 04-03-2004, 11:30 AM
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
I'm curious to know how a worn injector can cause a clicking noise in the engine. I'm sure there's a logical reason for this, but I cannot think of one at the moment.
<a href='
target='_blank'><img src='
border='0' alt='user posted image' /></a>
detour54 is offline
post #5 of 12 (permalink) Old 04-03-2004, 06:10 PM Thread Starter
The clicking speed increases as the revs increase and you can barely hear it when the engine is idling. It sounds embarrassing when you are gearing down and the revs go up and you hear this annoying clicking noise. One thing I should point out is that the previous owner now tells me that he blew the head gasket about 1 year ago and they repaired it by welding the crack in the head. Could it be a dodgy head?
mrpauly is offline
post #6 of 12 (permalink) Old 04-05-2004, 10:54 PM
greenlightracer is an unknown quantity at this point
Send a message via AIM to greenlightracer Send a message via MSN to greenlightracer Send a message via Yahoo to greenlightracer
Hey,
My car starting doing that today! though u can hear it when its at idle. Actually, the car idles rough too... And I just bought the car friday.
Brian
greenlightracer is offline
post #7 of 12 (permalink) Old 04-05-2004, 11:11 PM
Aether's Avatar
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
My 325 has an extremely slight click to it, which I can't hear over the transmission above like 2500rpm. Probably just a valve or something.
Four Five Six -
Aether is offline
post #8 of 12 (permalink) Old 04-06-2004, 12:17 PM
'85 318i's Avatar
'85 318i is an unknown quantity at this point
Send a message via AIM to '85 318i
probably a valve.
No posers, hacks or sellouts allowed.
&quot;Only posers die...&quot; - Stevo &quot;SLC Punk!&quot;
'85 318i is offline
post #9 of 12 (permalink) Old 04-06-2004, 06:13 PM
will1506 is an unknown quantity at this point
I had the very same problem with my 84 325e. Really loud tickng noie from the engine. 2 possible reasons. 1. blown cylinder head then you better think of a new car. 2. lifters are just loose over time. You can get them re tighten by a mechanic.
will1506 is offline
post #10 of 12 (permalink) Old 04-07-2004, 09:58 AM Thread Starter
Good news....i had my mechanic reset the valves and the clicking/ticking noise is gone now. It sounds alot better especially with the lambros hi-tech exhaust. But my mechanic now tells me that my exhaust header/extractor has a crack in it which is affecting idle and power. Will need to get that repaired soon and I will have a problem-free 325is.
mrpauly is offline
post #11 of 12 (permalink) Old 04-26-2004, 04:43 PM
Ronny is an unknown quantity at this point
In what way is it affecting idle?
Does the rev member to up and down slightly in idle?
Ronny is offline
post #12 of 12 (permalink) Old 05-25-2004, 12:38 AM
300k 325e is an unknown quantity at this point
the valves probably need to be adjusted, has anyone done this themselves? i plan on undertaking this task while replacing my valve cover gasket, any special tools needed?
300k 325e is offline
Engine Noise FIVER 5-Series (E12,E28, E34, E39, E60) 1 10-27-2005 11:21 AM
engine swap 92 325is to 99 M3 zinger 3-Series (E36) 6 02-29-2004 03:55 PM
325is vs. m3 engine..... 1985bmw325e 3-Series (E21, E30) 34 01-23-2004 04:40 PM
Engine series code for a 1990 325is? AE101 3-Series (E21, E30) 9 09-20-2003 11:02 PM
BMW P83 Engine triggrhaapi Bimmer Talk/Motorsports Talk 0 07-21-2003 03:03 PM
