| disconnect your exhust, oxygen sensor, loosen the belts on the front so you can remove them disconnect any wires going to the head and or hoses. by the way their is a sneaky little coolant hose on the back side of the head near the fire wall once you get the timing belt cover off the frount of the engine loosen the tensioner and remove the belt AND REPLACE IT ALONG WITH THE BELT TENSIONER AND SPRING, remove your valve cover and remove the head bolts in the opposite order that you would tork them so you dont worp the head. i have left some things out other people can fill in the blanks that just the most obvious stuff. |
