e21 camshaft - BMW Forum - BimmerWerkz.com
Old 05-12-2004, 06:45 PM   #1 (permalink)
bikesandcars is an unknown quantity at this point
I have a basic cam quiestion I hope someone can help with.
I have a 79 motor I am rebuilding. I plan on adding a turbo to it and wanted to use the stock cam from an 81-83 motor. Will that cam fit? Does anyone have a recommendation on lobe angle and duration?
bikesandcars is offline   Reply With Quote
Old 05-13-2004, 08:05 PM   #2 (permalink)
The issue is what distributor will you use.
1980 and earlier rotated clockwise.
1981 and later rotaed the other way, so the distributor determines the needed cam.
The cam profile is not as important on a forced induction engine since the cylinder is filled during 90 deg. of rotation, versus 45 deg. in a normally asperated engine.
Remember the intake charge is under pressure and as soon as the valve opens the cylinder will fill not when the piston causes a suction.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Fault Code: Camshaft Sensor kvadgama 3-Series (E36) 4 11-17-2008 11:23 PM
Camshaft Position Sensor gigsy 5-Series (E12,E28, E34, E39, E60) 1 10-24-2005 12:08 AM
e21 suspension for sale dubes1982bmw320i 3-Series (E21, E30) 0 09-22-2005 04:49 PM
Camshaft Sensor RICK_E46 3-Series (E46, E90) 2 10-08-2004 08:10 AM
camshaft position sensor > now oil leak? dakotan2 5-Series (E12,E28, E34, E39, E60) 0 05-20-2004 05:46 PM
