E 30/ Need advise on a serious fast idle - BMW Forum - BimmerWerkz.com
Old 02-07-2009, 09:22 AM   #1 (permalink)
Wydell is on a distinguished road
Angry E 30/ Need advise on a serious fast idle
My 1986 325e idle is extremely high when sitting still. Even with the idle adjustment screw backed all the way out. Checked hoses and did'nt find any leaks. I'm at a lost. Need Help.
Thanks,
Wydell
WydellConley@aol,com
Wydell is offline   Reply With Quote
Old 02-07-2009, 12:20 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Sounds like you either have a vaccum leak on an air intake hose or the MAF ( mass air sensor) has died. Unplug the maf and see what happens,situated between the air box and intake manifold
Old 02-07-2009, 05:21 PM   #3 (permalink)
guitarhound is on a distinguished road
Could be the idle control unit above the glove box...Usually you get a bouncing idle when it goes bad, but you never know...
guitarhound is offline   Reply With Quote
Old 02-07-2009, 07:05 PM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
check the throttle plate make sure it isnt hanging open and your car has an AFM not a MAF
1992 318i Coupe parts car
I am Captain Obvious
Old 02-09-2009, 10:44 AM   #5 (permalink)
igi_steel's Avatar
Car: 1990,bmw,320i
igi_steel is on a distinguished road
Maibe the valve for idle speed its problem.Its conected on the left side of big air inteake hoses between the air box and inteake manifold.Try to clean that valve with wd40
igi_steel is offline   Reply With Quote
Old 02-09-2009, 07:23 PM   #6 (permalink)
k.sidlosky's Avatar
Car: 06 Ranger, 03 Accord, 96 m3 s52!
k.sidlosky is on a distinguished road
Send a message via AIM to k.sidlosky
I had the same problem either you tps is bad or you just have to adjust it when mine went bad it would bounce from 700rpm to around 2k rpm then at some points it would just stall if you do replce it make sure it is adjusted right when you put it in or it will either idle high or not at all
k.sidlosky is offline   Reply With Quote
Rough idle & jumping idle ///M Power 3-Series (E36) 4 12-22-2008 05:20 PM
when i turn on the ac in my car and i am at idle the engine idle fluctuates ? träumer 3-Series (E21, E30) 0 11-01-2005 02:39 AM
85' 318i Fast Idle Escaped101 3-Series (E21, E30) 5 04-28-2005 11:59 PM
yea! Fast fast fast Numark318i Driving Tales 30 08-05-2004 01:53 PM
