| You will need the E30 M3 driveshaft with that setup as the trans length is different...if you were using the E30 Getrag(M50 trans) it would bolt right up to the stock driveshaft, but with the ZF you need the E30 M3 stuff
__________________ Kyle Sutherland
1995 BMW 540i/6: The Calypso Beast Vid 0-70ish 1987 BMW 325es: Face & Butt Lifted/M50tu Swapped *Sold* 1985 VW Scirocco: Too many mods, money pit *Sold* E34 Plate Filler Wanted! |
