Drive Axle Nut - BMW Forum - BimmerWerkz.com
Old 03-24-2005, 04:45 PM   #1 (permalink)
CuriousMustangGuy is an unknown quantity at this point
Hey guys I'm trying to change my rear wheel bearing today it got so bad that the left rear wheel locked up on me. good thing I was just pulling into a parking lot. Anyway I'm trying to get off the drive axle nut and it's huge anyone know the socket size so I don't buy 4 differnt ones?
It's stock. WHAT!
CuriousMustangGuy is offline   Reply With Quote
Old 03-25-2005, 04:18 AM   #2 (permalink)
draculia is an unknown quantity at this point
32mm i believe
draculia is offline   Reply With Quote
Old 03-25-2005, 04:56 PM   #3 (permalink)
Thanks, I'm having the hardest time getting this thing off, is it reverse threads?
It's stock. WHAT!
Old 03-26-2005, 10:29 PM   #4 (permalink)
nope. i used a breaker bar and it came right off. there should be a locking plate in there that needs to be removed before you can loosen it
Old 03-27-2005, 10:03 AM   #5 (permalink)
[snapback]319109[/snapback]
haha! I think the locking plate and the nut forged together. The cars body has 230,000 miles on it, and I don't think this nut has ever came off before. I'm going to get it welded off next week HAHA! ghead
It's stock. WHAT!
Old 03-28-2005, 05:56 PM   #6 (permalink)
welded off? That happens from time to time especially if its the original bearing
Old 03-29-2005, 10:53 PM   #7 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
It might be a 36mm. Get yourself a big 1/2" drive breaker bar and go at it. Other than having a good 1/2" impact that is about the only way to get it loose.
My M50 Powered E30 Page
Old 04-10-2005, 08:23 AM   #8 (permalink)
Well before I go welding this nut off I'm probably going to need one of those re-threader deals what is that called? Or maybe I can buy that part itself and if I can what the hell is that part called?
It's stock. WHAT!
Old 04-11-2005, 05:43 PM   #9 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
[snapback]329396[/snapback]
from the factory its on there @ 220ftlbs. that was 15+ years ago. needless to say i had to stand on the breaker bar (i weigh 210lbs) before mine came off.
when i removed mine off my 89 bmw it was a 36mm. could be different on different years if they have ABS, but to my knowledge they are all 36.
if needs be, what you are looking for is a "die" thread cutter.
Old 04-12-2005, 12:25 PM   #10 (permalink)
Originally posted by nukeduster+Apr 11 2005, 05:43 PM--><div class='quotetop'>QUOTE(nukeduster @ Apr 11 2005, 05:43 PM)</div><div class='quotemain'><!--QuoteBegin-CuriousMustangGuy@Apr 10 2005, 05:23 AM
Well before I go welding this nut off I'm probably going to need one of those re-threader deals what is that called?* Or maybe I can buy that part itself and if I can what the hell is that part called?
[snapback]330284[/snapback]
[/b][/quote]
thanks man, now if I use the die, will the same size nut fit? I like to ask all the questions before I go tearing up stuff.
It's stock. WHAT!
Old 04-13-2005, 04:35 PM   #11 (permalink)
Bump: someone please help the cars been in the driveway now for about 2 weeks. Before I act I know someone out there had to have used a die before, please just let me know if the same size nut will fit back on.
It's stock. WHAT!
Old 04-13-2005, 04:53 PM   #12 (permalink)
nukeduster's Avatar
[snapback]331728[/snapback]
depends on how bad you screw up the threads
if they arent totally ruined you just use the die to chase the threads just like you do a tap before re-installing important bolts, but if they are totally gone, honestly, i dont know what you'd do
start looking for a new rear hub mount (is that bolt part of the rear trailing arm? god I cant think right now) at a junk yard.
Old 04-13-2005, 05:58 PM   #13 (permalink)
have you used a breaker bar on it? did you bend the tab back?
you shouldnt have to cut it off
Old 04-13-2005, 09:41 PM   #14 (permalink)
[snapback]331780[/snapback]
Well here's the deal. Two weeks ago when I went to get the nut off I used a Haynes manule which said nothing about a lock plate for the 3 series so I went ahead and started to try and get the nut off rounding off the edges. Then without using my head I started to chisle it off. This made things worse and if I had a camera I would show you how f-ed up it is. Now this is where I'm stuck I could have it welded off but at the risk of something behind it warped or something because of the heat, or well I dono. any ideas??? I was going to drive it slowly to a shop that works on imports, but in my neiborhood out of that wheel smoke started comming out. I stopped and it smelled like the breaks, so now it looks like I have another problem on my hands. This cars starting to make me mad
It's stock. WHAT!
Old 04-19-2005, 01:31 PM   #15 (permalink)
ghead ghead ghead well I had it towed yesterday and now they say I need the whole lower control arm because it fell apart when they took it off. I just ordered one from Vines BMW whole sale for $100 not to bad I guess. Hopefully I'll be driving her at the end of the week.
It's stock. WHAT!
Dynamic Drive (e60) jbaxter 5-Series (E12,E28, E34, E39, E60) 0 04-14-2005 02:23 AM
Norcal Bay/sacto 3/26/05 Big Meet m3dragon California 5 04-02-2005 03:20 PM
Bent Drive Shaft Bimmer///Man3 3-Series (E36) 3 08-28-2004 01:17 AM
CV axle installation angryrobots 3-Series (E21, E30) 0 07-26-2004 09:31 PM
BMW Ultimate Drive SoonerE39 Bimmer Talk/Motorsports Talk 8 06-13-2003 04:29 PM
