Diagnostic Connector Analyse - BMW Forum - BimmerWerkz.com
Old 01-21-2005, 11:31 PM   #1 (permalink)
{NTM} is an unknown quantity at this point
Send a message via MSN to {NTM}
I need information about some software and hardware i need to connect my car (325 IX 89) on a pc for analyse it. I know that carsoft have a software but what else?
Can i make a home made connector just for read car code. And if yes, how can i decode it?..If some one have great information web page about how work the BMW diagnostic system it will be very usefull. I have found lot of think about ODB II but not for BMW.
Thx for all information, more i have, easyless will be my project :-)
BMW 325IX Black, Build for drift
{NTM} is offline   Reply With Quote
Old 01-22-2005, 01:01 AM   #2 (permalink)
OK, the diagnostic connector is one way to get the information.
The other is the key and stomp.
Diagnostic for the OBD II
Here are some connector information points.
http://www.unofficialbmw.com/images/reset1.gif
1. Ground
4. Temperature sensor
7. Reset
8. TDC sensor yellow
9. TDC sensor shield
10.TDC sensor black
11.Start signal
12.Alternator charging excitation voltage
13.Ignition coil
14.Alternator charging supply current
15.Oxygen Heater
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 01-22-2005, 08:55 AM   #3 (permalink)
Yes i found this information about tis tool. But what i whant to do its to plug it permanent to a my laptop in the car to see all information when i'm run the car. (Like your personnal picture in your post, a software that show me all information about the car, like O2, rmp, speed ect,,,)
thx a lot for your help
Old 01-22-2005, 03:51 PM   #4 (permalink)
Kowalski's Avatar
[snapback]276658[/snapback]
hey i like that idea, how would you go about doing that on a 91 318is? im guessing buying hte diagnostic cable and hooking it up to a usb port some how, maybe it comes with one and then you'd need decoding software, and if you had all that im guessing you could change stuff right? im not much for computers, more the mechanical side of things, thats what i try to stay away from newer cars... howevr i couldn't resist the E30
264* roatation and 388 lift
M43, Diagnostic Plug samh 3-Series (E36) 1 12-12-2004 11:42 AM
E30 *sudden* death ... need diagnostic help, pls. blakersE30 3-Series (E21, E30) 4 09-11-2004 10:10 PM
Engine Diagnostic question tiremann34 3-Series (E36) 6 08-11-2004 09:03 AM
318i obd diagnostic plug AndyBaloch 3-Series (E36) 2 07-13-2004 01:19 AM
