Quote: Originally posted by tyro2001@Apr 29 2005, 10:22 AM on my old car that used to happen every now and then, also when that happened my clock light would go out too?
i fixed it by hitting the top of the dash board with my hand while driving around 30-40mph. i dont know why 30-40mph but its weird?
try that and see what happens could be something loose then. [snapback]339208[/snapback] | if everything else works its most likely the speedometer pickup located on the rear differential. their connectors have a tendency of oxidizing and not sending the signal like they should.
pull the electrical boot off the connector on the rear differential and look at the condition of the pins. spray them down really well inside the connector and on the pickup itself with contact cleaner or WD40 and wait a bit, then clean them off a bit with a small wire brush if you have one.
hook it back up and hopefully it'll work again, otherwise the sensor itself could be bad, or its a problem with the dash.
most likely the sensor.
__________________ When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko |
