Dashboard Engine Oil Light - BMW Forum - BimmerWerkz.com
Old 05-13-2005, 12:26 PM   #1 (permalink)
moetinger is an unknown quantity at this point
The light on my dash flickers sporadically. My mechanic said my oil pump might be going bad. with my experince with this car, I think it might be a bad sensor or connection. I've got pletny of oil so I know that is not the prob.
Any input would greatly appreciated.
Also, what does everyone think about 16" TSW hock r's for rims?? I can get a killer deal on a set for my convertible.
Thanks!
moetinger is offline   Reply With Quote
Old 05-13-2005, 12:29 PM   #2 (permalink)
ae.cowboy's Avatar
ae.cowboy is an unknown quantity at this point
Your mechanic could be right, that sensor is an idiot light for oil pressure, and if its on, then you need to STOP driving, b/c that means that your oil pressure is super low. But it could also be a short somewhere in that circuit, causing the light to come on. Do you notice any drivability problems??? Lack of acceleration or anything that could be caused by low oil pressure???
1986 BMW 325
**Full custom 2 1/2 exhaust, no cats**
**Chipped***
**Member of the Lone Star Club**
**Member of the Ticket for Passing on Left Shoulder Club**
(I actually got that ticket dismissed lol)
ae.cowboy is offline   Reply With Quote
Old 05-13-2005, 12:37 PM   #3 (permalink)
[snapback]344178[/snapback]
The accelaration seems fine and in all honesty, I have been driving the car ever since I bought it (about 15K miles ago) just like that. If you think this is a serious prob that needs to be addressed so be it. Cheaper than replacing the engine!
Old 07-27-2005, 04:44 PM   #4 (permalink)
Tadao is an unknown quantity at this point
Originally posted by moetinger+May 13 2005, 11:37 AM--><div class='quotetop'>QUOTE(moetinger @ May 13 2005, 11:37 AM)</div><div class='quotemain'><!--QuoteBegin-ae.cowboy@May 13 2005, 11:29 AM
[snapback]344183[/snapback]
[/b][/quote]
I have never seen my oil pressure light come on, even when I'm starting (when I think it is supposed to come on for a bit and shut off after the car is started). I changed my oil pressure switch (because it started leaking oil) and the light still never comes on. I'm nervous that something could be wrong, or that it could go really wrong if I lose pressure and the dummy light doesn't tell me. Any ideas on this?
Thanks,
Mark
Mark
1984 325e
Tadao is offline   Reply With Quote
Old 07-29-2005, 01:43 AM   #5 (permalink)
Kowalski's Avatar
Originally posted by Tadao+Jul 27 2005, 02:44 PM--><div class='quotetop'>QUOTE(Tadao @ Jul 27 2005, 02:44 PM)</div><div class='quotemain'>
Thanks,
Mark
[snapback]365552[/snapback]
[/b][/quote]
the bulb is probably burnt out.
264* roatation and 388 lift
Old 07-30-2005, 11:51 AM   #6 (permalink)
Angelic0-'s Avatar
Angelic0- is an unknown quantity at this point
Send a message via MSN to Angelic0-
Originally posted by Kowalski+Jul 29 2005, 06:43 AM--><div class='quotetop'>QUOTE(Kowalski @ Jul 29 2005, 06:43 AM)</div><div class='quotemain'>
Thanks,
Mark
[snapback]365913[/snapback]
[/b][/quote]
Or someone pulled out the bulb since it was on continously
Anyhows, check the bulb first
| BMW E36 325i | BMW E34 520i | BMW E39 "M5" | BMW E60 530d MAPPED | BMW E38 740iA | BMW E32 750iAL |
Originally Posted by Mazi!
Viktor :|
Angelic0- is offline   Reply With Quote
Old 07-30-2005, 02:41 PM   #7 (permalink)
schilke's Avatar
schilke is an unknown quantity at this point
As for the original question...
Some of them BMW sixes were prone to having the oil pump disassemble itself and fall into the oil pan. Eights especially. I think you may want to have your oil pump looked at or replaced. Those lights don't really go haywire too often.
Do you think you may have some sludge in the engine? That may cause the low pressure too...
Need a new sig...
A BMW is for the soul, a Chevy is for groceries...
BAN KRAFTFAHRER!!!!
schilke is offline   Reply With Quote
'94 318is Uneven Idle. Check Engine Light On ultraviolet353 3-Series (E36) 8 12-19-2004 11:17 PM
Check Engine Light E46 '04 M3 frw73 M-Series (M1, M3, M5, M6) 4 08-24-2004 10:20 PM
check engine light Kubna 5-Series (E12,E28, E34, E39, E60) 7 06-28-2004 02:00 AM
'88 M6 Check engine light jfries 1,6,7,8 - Series and Mini Cooper 0 05-27-2004 09:37 PM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
