Dash lights not working anymore - BMW Forum - BimmerWerkz.com
Old 04-07-2007, 03:35 AM   #1 (permalink)
MirrorImage is on a distinguished road
Red face Dash lights not working anymore
Just recently, the dash lights in my '91 318is stopped working. When I pull the switch the exterior lights work fine but the dash doesn't illuminate. I've turned the knob but it's not a dim illumination thing. I've checked/moved all the 7.5A fuses to new positions with no effect.
The lights not working: main instrument cluster, heating controls, clock, rear demist button. The actual instruments, heater, clock, rear demist themselves work fine.
Any help gratefully received.
[Here in the UK we have speed cameras pretty much everywhere. So not being able to see the speedo is a real problem when driving at night.)
MirrorImage is offline   Reply With Quote
Old 04-07-2007, 07:01 AM   #2 (permalink)
snpower is an unknown quantity at this point
This happened to me a few years ago, I changed out the entire dimmer knob assembly and all was well...
snpower is offline   Reply With Quote
Old 04-07-2007, 12:04 PM   #3 (permalink)
Thanks - I'm taking your advice and have just found an assembly on ebay. What did we used to do before helpful forums & eBay to fix these problems? Once again, many thanks.
Old 04-07-2007, 01:04 PM   #4 (permalink)
I hope this is what you got ?
eBay Motors: BMW E30 HEADLIGHT SWITCH 84-91 318 325 M3 92 CONV (item 230113993670 end time Apr-10-07 17:31:33 PDT)
Old 04-07-2007, 01:20 PM   #5 (permalink)
Man, that is so helpful. As it happens, I found this one on eBay UK:
eBay.co.uk: bmw e30 light switch with surround (item 110112355219 end time 14-Apr-07 12:44:09 BST)
I hope it's the right one, 'cos the US ad suggests there may be differences after 1988 & I've got a '91 318is.
Old 04-07-2007, 02:45 PM   #6 (permalink)
Check out this link, and try to find the correct part number before you bid:
Select your BMW model
It's an online parts catalog. Very good.
If I remember correctly there is also a relay for the interior lights; in my case it tested o.k. - you may want to make sure the relay is good first. Your symptoms matched mine exactly though.
Old 04-07-2007, 04:43 PM   #7 (permalink)
Wow, that's an incredible resource. I now know correct part no. & will confirm before bidding. Good idea to check the relay - I haven't a clue about this - where would I find it & what am I looking for! Sorry to be so dumb.
Old 04-07-2007, 07:44 PM   #8 (permalink)
No problem! I was just as dumb two years ago when I bought my '90 325ic.
I just checked my notes and I mis-spoke. The relay I'm thinking of works the hazzard lights only. There is, however, a control unit relay for the interior lights. I could not find it's location though. It's $80.00. I'd definitely try a new rheostat switch like we discussed above.
Old 04-07-2007, 09:11 PM   #9 (permalink)
Car: 1992/BMW/325IC
wayneo325IC is on a distinguished road
Send a message via AIM to wayneo325IC Send a message via MSN to wayneo325IC
The interior light relay is behind the front speakers. Changed mine a few weeks ago and now i have interior lights when i open my door!!!
and my dash lights stoped working a few months back and changed the
rheostat switch and all is good!!!
wayneo325IC is offline   Reply With Quote
Old 04-08-2007, 02:08 AM   #10 (permalink)
My hazzards and interior (door switched) lights are OK - it's strictly dashboard/front console that's the problem when I pull that little knob! I'm gonna change the light switch/dimmer assembly unit - sounds like that will resolve the issue. Thanks guys especially snpower for your time & advice - much appreciated.
Old 04-14-2007, 06:19 AM   #11 (permalink)
Any updates ?
Fog Lights Aren't Working YoungExec728 3-Series (E36) 13 04-26-2010 12:22 PM
Dash Indicator Lights john_k_o 3-Series (E21, E30) 4 03-06-2006 02:56 PM
Dash Lights metalmayhem 3-Series (E36) 0 12-25-2004 04:35 AM
2000 323CiC License Plate Lights Not Working seelinger 3-Series (E46, E90) 0 06-01-2004 05:31 PM
reverse lights suddenly stoped working mstar 3-Series (E36) 5 05-28-2004 06:16 PM
