Crankshaft Stuck - BMW Forum - BimmerWerkz.com
Old 04-03-2009, 03:59 AM   #1 (permalink)
bobome is on a distinguished road
Crankshaft Stuck
I'm trying to replace the cylinder head on my 87 325is but when I tried to line up the TDC, I can not turn the crankshaft. This is the fourth or fifth time I replaced a cylinder head but this is the first time I'm having trouble turning the crankshaft. Could it be the pistons got rusted? Coolant was mixed with oil when I drained the oil and the car been sitting for 2 months after the head gasket blown. Anybody got any idea why the crankshaft got stuck? The car is 5-speed. Your advices/comments are greatly appreciated.
89 325iC 5sp
90 325iC Auto
bobome is offline   Reply With Quote
Old 04-03-2009, 10:23 AM   #2 (permalink)
beamerboy325is's Avatar
beamerboy325is is on a distinguished road
roll it back and fourth in gear, that should fix your problem.
beamerboy325is is offline   Reply With Quote
Old 04-03-2009, 11:56 AM   #3 (permalink)
Thanks for your advice. I tried rolling it in first gear couple of days ago but still stuck. I will try to roll it again tonight and see if it work. Thanks
89 325iC 5sp
90 325iC Auto
Old 04-03-2009, 12:12 PM   #4 (permalink)
elsabor67's Avatar
Car: '09 135i ///M Sport Pkg
elsabor67 is on a distinguished road
Send a message via MSN to elsabor67
Pistons won't get rusted to that point in 2 months. Was it still running when you removed the head?
How do I spell relief?!?!?!
NO MORE DAMN SNOW!!!!!!
elsabor67 is offline   Reply With Quote
Old 04-03-2009, 01:14 PM   #5 (permalink)
Ok try lubing the engine and then roll it,best luck.
Old 04-04-2009, 03:01 PM   #6 (permalink)
No, it was not running when I took the head off, in fact, it died on the freeway while I was driving have to towed it back home. Sat on the street for 2 months before I have time to work on it. I'm going to give it a try now and I'll update you in a few hours. Thanks.
89 325iC 5sp
90 325iC Auto
Old 04-05-2009, 04:10 AM   #7 (permalink)
elsabor67's Avatar
Do you know if the Timing belt snapped? If so, your block is locked and you're better off getting a new engine. Good luck.
Old 04-05-2009, 06:10 PM   #8 (permalink)
so you are saying that you can't turn the crankshaft with the cylinder head off? that would be a serious thing
silversled is offline   Reply With Quote
Old 04-09-2009, 12:14 PM   #9 (permalink)
No, the timing belt did not break, it's one piece when I took it off. The car overheated before it broke down on the freeway. When I drained the motor oil, coolant came out first for about 5 second before any oil started coming out. To lube the engine is to pour motor oil on the pistons?
89 325iC 5sp
90 325iC Auto
Old 04-10-2009, 08:58 AM   #10 (permalink)
elsabor67's Avatar
If you had collant coming out of your oil, your head gasket is shot and your engine is seized. There is no ammount of lubing that will unsieze those pistons.
I advise you to take it to a mechanic so he can give you an assesment of how much it's gonna cost to get a new engine.
Crankshaft positioning sensor not aligned aubreytp 3-Series (E36) 1 02-25-2009 09:34 AM
crankshaft position sensor wabenzy 5-Series (E12,E28, E34, E39, E60) 2 12-18-2008 01:11 PM
E34 pistons, connecting rods and Crankshaft Saggis 5-Series (E12,E28, E34, E39, E60) 0 03-23-2006 03:03 AM
Crankshaft Pulley Rubber Debonding jeremydo 5-Series (E12,E28, E34, E39, E60) 1 03-31-2005 08:22 PM
M44 Crankshaft dclaw Classifieds Sell & Buy 0 02-14-2005 04:17 AM
