| we need a little more info on what you are trying to accomplish. What is it that your doin that you want to turn the crank shaft? the timing belt is off the car? you can always put it back to TDC as long as it is there when you want to put the belt back on. The camshaft should be at TDC when you take the belt off cause there isnt really any way to turn it. You can turn the crank shaft all day long |
