Coolant Question - BMW Forum - BimmerWerkz.com
Old 03-06-2004, 10:08 AM   #1 (permalink)
charles01 is an unknown quantity at this point
I have a BMW 316i 1990 (old shape).
The radiator bleed screw thread broke without being touched & I lost some coolant.
I've put a new official BMW Bleed screw back in. I've needed to top up the coolant twice since. The engine temperature gauge reading is normal & there is plenty of heat blowing from the cabin heater. There is no sign of any coolant leak now.
Does the need for me to top up the coolant again mean that there is air in the system & that it should be bled?
Secondly, if I needed to bleed the coolant - do I remove the bleed screw with a cold engine, let the engine heat up, put the cabin heater on max. heat & blower on, & then watch for air bubbles from the bleed screw?
Thanks, Charles.
charles01 is offline   Reply With Quote
Old 03-06-2004, 06:57 PM   #2 (permalink)
You have the bleeding procedure exactly as needed.
But unless there is a reason why bleed it.
Do not fix what is not broken.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Last Coolant Question dvmotorsports 3-Series (E36) 5 06-11-2005 06:50 PM
Coolant Question dvmotorsports 3-Series (E36) 6 06-10-2005 09:31 PM
Aux Water Pump/ Coolant Hoses Question? Ted K 5-Series (E12,E28, E34, E39, E60) 0 03-06-2005 10:52 AM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
E39 coolant level sensor NC540i 5-Series (E12,E28, E34, E39, E60) 4 05-27-2004 12:56 PM
