Coolant loss when engine turned off - BMW Forum - BimmerWerkz.com
Old 04-24-2009, 01:01 PM   #1 (permalink)
slartibartfast is on a distinguished road
Hi,
does anyone know what is happening? Temperature guage is normal, but as soon as I switch off the engine after running for an hour or so, then coolant leaks from the pressure valve (several pints). I assume that as soon as I switch off the engine then the engine heat is boiling the water but what is occuring that doesn't under normal operation? I have no idea .....
slartibartfast is offline   Reply With Quote
Old 04-24-2009, 07:00 PM   #2 (permalink)
yeah, I know what's going on...you have too much water and not enough antifreeze in your system. The steam from boiling water seeps after shutdown...antifreeze is also antiboil.....I'd change the coolant altogether after tightening all of the hose clamps and see what happens...good luck
silversled is offline   Reply With Quote
Old 04-27-2009, 02:29 AM   #3 (permalink)
Many thanks
Thanks .... will try over next few days. A lot cheaper than I was expecting!
Old 04-27-2009, 02:32 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
You may also find a new radiator /expansion tank cap may be a good idea too.
Engine Temp Drops When Heater Is Turned On wulley1 3-Series (E36) 19 11-25-2007 10:55 AM
Check Engine Light Turned On... Turbodefrost 3-Series (E36) 23 03-29-2005 02:09 AM
1993 740i Clicking After Engine Turned Off kmac123 1,6,7,8 - Series and Mini Cooper 1 03-09-2005 08:20 PM
