COOLANT LIGHT - BMW Forum - BimmerWerkz.com
Old 08-30-2004, 07:58 PM   #1 (permalink)
shield is an unknown quantity at this point
This morning, as i started my car up, the coolant light stayed on. I checked the level and it was fine. No leaks or anything. Does this mean the water-pump has problems?
I also have another issue. The temperature gauge is "bouncy" it bounces all of a sudden but it never passes the middle. But most of the time, it seems like it's running cold.
So whatsup with the coolant light? and could the gauge thing be related? maybe a fauly thermostat??
thanks in advance...
shield is offline   Reply With Quote
Old 08-30-2004, 08:17 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Sounds like you need a new coolant level sensor and check the connections on the back of your cluster, that will cause the gauge to bounce.
My M50 Powered E30 Page
Old 08-31-2004, 12:16 PM   #3 (permalink)
seandaly is an unknown quantity at this point
I had the same problem. Replaced the coolant level sender and all is well. Also, the coolant level must be kept right up to the fill mark or the coolant light will come on while cornering.
My temp gauge also bounces around and like yours, never passes the midpoint, and usually indicates it's running a tad cool. Then again, almost all my gauges bounce all over the place and go in and out! Will eventually pull the whole cluster and check it out, but it's kinda low priority right now.
seandaly is offline   Reply With Quote
Check Coolant Light M3wannabe2004 3-Series (E36) 7 03-26-2005 09:48 AM
Why Is My Coolant Light On EnvyM3 3-Series (E46, E90) 3 01-31-2005 09:17 PM
Coolant Light Comes On EnvyM3 3-Series (E46, E90) 1 11-08-2004 09:40 PM
Coolant light is on Old_School_Bimmer 3-Series (E21, E30) 5 07-26-2004 01:37 AM
