Coolant Leak--no Idea Where It Is Coming From! - BMW Forum - BimmerWerkz.com
Old 05-24-2005, 09:09 AM   #1 (permalink)
moetinger is an unknown quantity at this point
Right behind the drivers side front tire (closer to the driver-not closer to the front of the car) my car is leaking antifreeze and it is looks like it is coming out of the chassis. Does anybody know what hoses could be up there?
Thanks!
moetinger is offline   Reply With Quote
Old 05-24-2005, 09:58 AM   #2 (permalink)
Mad_Milo is an unknown quantity at this point
Send a message via AIM to Mad_Milo Send a message via Yahoo to Mad_Milo
There is an assortment of hoses on the back side of the engine.
There are 2 going in/out of the heater core on the firewall, maybe a snarl of hoses from the early 80's bypass recall, and some hoses going to/from the intake and throttle body.
Get your car up to temp with the coolant full, shut it down, and pop the hood. Use your eyes, ears and nose and you should be able to trace them around. Give the hoses a squeeze near the clamped ends and in the middle, and you may find/hear some bubbling or hissing.
Go to RealOEM and enter your info, and then find the cooling system schematic for a list of standard hoses and approximate locations. It doesn't have the bypass on the older cars though.
Mad_Milo
1984 325e - Delphin Grey
Damn near stock, for now.
Mad_Milo is offline   Reply With Quote
Old 05-24-2005, 11:02 AM   #3 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
the spot you described is the pressure overflow outlet. its for if you over-fill your coolant tank, it dumps out the excess coolant right behind the drivers front wheel. there is a hose that feeds down through there that lets it leak out onto the ground there.
you DONT fill the coolant system all the way to the top. otherwise, the situation you are describing happens, and everytime you check yoru coolant you will be like "WTF? wheres my coolant going?" well, its overfilled, so its getting forced out.
its normal, dont worry about it.
Old 05-24-2005, 11:09 AM   #4 (permalink)
That would make sense b/c I had no choice but to drive my car another 45 minutes and the temp needle didn't budge. I would think if the car was low on coolant, it would over heat pretty quickly.
thanks for the help!
Old 05-24-2005, 11:51 AM   #5 (permalink)
That's assuming that the overflow is on that side. You never spec'd what car model or year you are driving.
My expansion tank and overflow is on the passenger side.
Mad_Milo
Old 05-24-2005, 11:54 AM   #6 (permalink)
1990 325 ic. The expansion tank is on the drivers side. About how full should it stay and should I be concerned that this is the first instance this has happened?
Thanks
Old 05-24-2005, 11:57 AM   #7 (permalink)
Fill it to the full line on the tank when cold. That should give you a good reference mark.
Mad_Milo
Old 05-24-2005, 01:31 PM   #8 (permalink)
offabroadway is an unknown quantity at this point
The garage I've been to a few times has added coolant for me once when my coolant light went off, they filled it with the engine running and hot to the full mark, and then some of it dissapeared. It's kept a pretty steady level since then, but I always wondered why the coolant was leaving.
Glad I checked in on this thread.
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 02-27-2006, 03:49 PM   #9 (permalink)
Redbullrr's Avatar
Redbullrr is on a distinguished road
I just started a thread regarding an issue like this. The car is not overheating. I do have heat in the car and I was sitting put for about 15 minutes waiting for someone, and when I took off I noticed a small pool of antifreeze this was when I shut the car off then turned it back on. It wasnt still leaking, but when I checked my rad overflow tank I still had fluid but about 3 inches high. When I looked underneath the car it was as if a water gun with antifreeze went off down there. It was over my rim, and axles. Could this be what is going on?
Redbullrr is offline   Reply With Quote
Old 02-27-2006, 06:21 PM   #10 (permalink)
Car: Opening soon:
Drivers side or passenger side. What year is your car?
Old 03-01-2006, 10:30 AM   #11 (permalink)
Redbullrr's Avatar
96 318IS. Its from the drivers side.
Old 03-02-2006, 05:41 PM   #12 (permalink)
Car: Opening soon:
Is it still doing it?
Old 03-07-2006, 12:54 PM   #13 (permalink)
fretsgonebad's Avatar
fretsgonebad is on a distinguished road
Send a message via AIM to fretsgonebad
I changed my coolant the other day and when i started up my car and let it run for a bit coolant started dripping like crazy out of this area on my car, too. It really freaked the crap out of me because i have never leaked coolant before. I drive a 1990 325i sedan. Is this the problem?
fretsgonebad is offline   Reply With Quote
97 540ia, Coolant leak, but cant find the source! ///Matt 5-Series (E12,E28, E34, E39, E60) 7 11-08-2005 11:25 AM
1997 328i Coolant Leak and Maintenance Larry Horne 3-Series (E36) 4 10-15-2005 07:45 PM
Coolant Leak From Sensor? BMW-ATI 3-Series (E36) 7 06-23-2005 07:41 AM
coolant leak white 330ci 3-Series (E46, E90) 2 09-08-2004 06:39 PM
Problem with the Coolant Leak RedBeemer95 3-Series (E36) 3 07-23-2004 02:53 PM
