| I dunno if the electrical is the same, but i had a similar problem with a '95 of the same model. The top sometimes won't shut all the way, then if you drive it with the top partially p or down, it has an automatic disengage. The best thing to do is to disengage all power to it, open and close it manually, then put power back to it. This usually fixes the problem. |
