Has anyone out there done there own control arm replacement on a '89 325i? How big of a pain in the arse is this? Any special tools required for the bushings or seperating the arms from the other assemblies?
The bushings are shot and there is some rattle in the front.....hence the new arms. There is a shop here that will do it for $450 (USD). Parts that I have found will run about $250. Is $200 worth the frustration, banged and busted knuckles ?
not a very big deal. its a pain getting to the control arm to subframe nuts though. once everything is undone a few taps from a hammer will pop them right out. i banged out the stock bushings from the "lollypops". a puller helps to get the old bushings off, but you could just cut them off.
you should be able to get a control arm complete with the bushings. I got a set for my old 318, it was pretty easy
__________________ <img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
Originally posted by Bimmin'88@Nov 5 2004, 11:03 AM You should be able to purchase complete set with new bushings. And it should not be that big of a project. Two hours Max.
[snapback]225098[/snapback]
thats what i just said
i'll kill you
hehehe werd
Check with PEP BOYS for installation price and ADVANCE or Auto Zone for control arms. Son-in-law had the same repair done at Pep Boys on 1990 325ic for a lot less than your quote.
