Control Arm Bushing Help - BMW Forum - BimmerWerkz.com
Old 09-18-2007, 05:11 PM   #1 (permalink)
snpower is an unknown quantity at this point
My '90 E30 failed inspection for dry rotting bushings. I bought the parts from Bavarian Auto that include the bushing already mounted in the lolipop bracket. I can't get the old bushing/bracket off either arm though. I've tried vice-grips, hammer and chisel - they just wont move a bit. Any other techniques to try?
snpower is offline   Reply With Quote
Old 09-18-2007, 05:32 PM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
??? they really check those for an inspection??
I think all they check here are lights/signals and maybe cracks in the windshield...
sorry I can't help.
yammahamma is offline   Reply With Quote
Old 09-18-2007, 05:49 PM   #3 (permalink)
I'm thinking a gear puller, although I've never used one and would not know which size to get.
Yes, they checked that. A shop I (normally) trust but man - $500.00 was the quote to do the job...
Old 09-18-2007, 11:14 PM   #4 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
your going to need a gear puller to get them off... i cheaped out and got the 2 legged one and regreted it (although it is possible to do i highly recommend against it) so you should go with the 3 legged puller. Just get one that looks like it would fit... even drill out the old bushing if you can get a better grip on it...
also putting on the new bushings is going to be a bitch... go ahead and buy some dawn dish soap to use as lube and start brain storming ideas on how you would get it on without a press... :\ i have a way which i got mine on but i know there has to be a better way so if you run out of ideas then PM me and ill see if i cant help you out...
Old 09-19-2007, 12:19 AM   #5 (permalink)
Car: 1994/BMW/325IS
Marknhl is on a distinguished road
Send a message via AIM to Marknhl
I had to do those bushings on my '94 E36 and they were no easy task. I had never done them before but I got a tip from the mechanic at the BMW dealership to use the gear puller. (I had to get my alignment done and I had to replace the bushings before they would do it. They thought they were going to make $385, it costs me $80? I forget. That or less.) Definitely a good idea. Just rent one. Pay for one? lol screw that, I'm in college. Anyway, the gear puller should get them off without too much hassle. I actually ended up using a torch and melting some of the rubber off and then the outside bracket came off, then I used the gear puller again to get the center bushing off the arm. As far as putting them back on, I mainly used a 3lb hammer. Get the new bushing and bracket started with a few taps, then take the old center bushing and put that in front of the new bracket and wail on the old bushing which will act like a damper. Your arms WILL get tired. Get over it and keep wailing until they're all the way on lol. If it makes you feel any better, I put the first one on backwards! So I had to then pull it off and do it again. Not fun, make sure you don't do the same. Good luck.
Marknhl is offline   Reply With Quote
Old 09-19-2007, 12:35 AM   #6 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
flame...thats how i roll or pickle fork, but i like fire...
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-19-2007, 08:18 AM   #7 (permalink)
DONE. I hope
Well let's hope so. I ended up using my 2006 Tacoma and a tow strap to press the bushing/bracket onto the control arm. Just slipped the truck into neutral and let it roll forward a tad. Worked like a charm on the right side. On the left side after multiple attempts I could not get the bushing as far up on the arm as on the right. I bolted it in place, torqued to specification, and will have the car re-inspected tomorrow.
Old 09-19-2007, 09:23 AM   #8 (permalink)
Car: 1994/BMW/325IS
When I did it I didn't even use soap or any type of lubricate on the control arm if I remember correctly. I'd be surprised if you couldn't get them on there with multiple goods swings and a BIG hammer. It's not easy, give it an hour or so but just don't give up, stay down there and get it done. Using the truck? Now that's a big of scary innovation lol
Old 09-19-2007, 02:25 PM   #9 (permalink)
Sodium Chloride
Car: 95 M3
mine was a bitch
Old 09-19-2007, 06:57 PM   #10 (permalink)
Awful job (for me anyway). Only worse one I've done was the oil pan. I'm sure the rest of the suspension is no cake walk either - ask me next spring!!
I beat the #$%! out of those things and they wouldn't budge enough to say so.
It's done and the inspection passed so cheers to me!!
I'm heading up to Portmouth, NH tomorrow (I'm a pilot) so I'll run over to Bavarian Auto and spend some more $$$...
Old 09-19-2007, 10:54 PM   #11 (permalink)
Sodium Chloride
Car: 95 M3
oil pan is cake heh :\ steal me some sways while your at BAV. would ya?
Control Arm eferree 5-Series (E12,E28, E34, E39, E60) 6 01-28-2007 11:43 AM
my shaking problem: Lower control arm csrumber1 3-Series (E21, E30) 3 09-19-2006 10:02 PM
Clearance Sale on front control arm bushings BMWJNKY 3-Series (E21, E30) 4 04-16-2006 10:51 AM
Thrust Rod (upper control arm)???? Sal329 5-Series (E12,E28, E34, E39, E60) 2 02-08-2006 05:56 AM
E36 Suspension Work, Want To Upgrade Suspension? victorgallas Product Reviews 8 02-08-2005 08:21 AM
