Where do I find complete engine available for Sale for my 1990 E30?
Either E30 M3 engine, E34 M5 engine or E36 325i engine.
And how much does it usually cost?
Originally posted by tomsbmw325is@Apr 12 2005, 08:09 AM Where do I find complete engine available for Sale for my 1990 E30?
__________________ When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko
if you are looking to swap, best bet is to find a wrecked car and get everything you need, in terms of cost and finding all the parts you need for the swap.
but in all honestly the motor you should be looking for should come out of a 533i, that would be your best bet. easiest to swap with the biggest gains.....oh and i wouldn't go E30 M motor, you want to increase the displacement not reduce it
__________________ sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
i am unsure of the HP gains with the 533i, but i know you are upping displacement to 3.3 and getting rid of your timing belt woes every 50k cause she is chain driven........i say this motor for a couple of reasons......1) it's a six banger, you mod a six you mod a four, six will always win. there is no replacement for displacement. true stock out of the box the M3 E30 motor is tons of fun, don't get me wrong......but you can mod this motor and be faster than the M3 E30 motor. which brings me to 2) cost.......first of all finding everything for the E30 M motor swap is going to be fun. you will need everything for the swap seeing how you are going from a 6 to a 4 banger......and everyone knows that BMW means Bring Money With you......and M means bring More money with you.......the cost of the M swap would be pricey. and if you split the difference and took the savings and invested into the 533i motor you would probably be faster at the end of the day, if nothing else rocking around with some extra cash in your pocket.....which brings me to the next question.......why not just mod your current motor? you can do the diesel crank drop in, a nice super charger, and/or the MAF and single throttle body conversion and be solid and making some very nice HP gains all for right around the cost of the swap or less........just something to think about.....
an S14 E30 M3 engine is a lot more expensive to purchase then a normal E36 M3 OBDI or II engine. and the E30 M3 takes more maintaince because of the chain, you needa adjust the valves a lot from what i hear.
so at bavengine, id suggest getting the S38(e34 m5 engine) or the e36 M3 OBDI engine(easier and better gains with modifying).
__________________ I hate: people who haven't died yet that I hate. L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc. 2000 BMW M Coupe - Dakar-II - S52 "You gotta fix the nut behind the wheel before you fix the bolts on the car"
Originally posted by spiff325is@Apr 13 2005, 10:28 AM an S14 E30 M3 engine is a lot more expensive to purchase then a normal E36 M3 OBDI or II engine. and the E30 M3 takes more maintaince because of the chain, you needa adjust the valves a lot from what i hear.
[snapback]331493[/snapback]
yes, that is another option, the E36 M motor........would be cheaper than the E 30 M motor, BUT here again you would need everything and i mean everything for the swap seeing how you are going over to a completely different FI system. but if you found a wrecked one, i would say rock it.....that would be an awesome swap
the m30 motor is a pretty easy swap from what i hear
bmw actually made a factory 333i using the m30 3.2 engine in the past (187hp if im not mistaken, but more torque then the m20b25 as well, not sure of actual #), so im sure there are motor mounts already floating around you could purchase.
alpina in the 80's also did m30 conversions for the e30 and made a couple different motor mounts, some of which did and didnt require modification of the firewall. the ones that did require modification are the best, as they mount the engine pretty far back.. enough so that they dont upset chassis balance.
or one of the more comical swaps i found was there was a fabricator about a year ago selling 4G63 motor mounts compatible with the e30 chassis. in case you dont know, the 4g63 is a mistu. EVO engine. not a bad engine, pretty light and 280hp.
-Dick Marcinko
