cluth? trans? wut is it?! - BMW Forum - BimmerWerkz.com
Old 08-26-2008, 05:00 PM   #1 (permalink)
82_320i's Avatar
82_320i is on a distinguished road
i have an 82 320i 5spd manual and for some reason almost everytime i go to reverse it grinds out like a mofo and wont let me go into it. it also did this once trying to go into first.
yes i am completely stopped when i go to reverse.
i go to my car sit down start it, put the clutch down try for reverse but it wont allow me to it just grinds i have to put it back in neutral then try again some times up to 3 tries.
help me please
SNAKE
82_320i is offline   Reply With Quote
Old 08-26-2008, 09:43 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
sounds like a clutch issue.... My toyota Pickup does this sometimes... do you have floormats?
1992 318i Coupe parts car
I am Captain Obvious
Old 08-27-2008, 12:05 PM   #3 (permalink)
82_320i's Avatar
i have been told that it sounds like the clutch is not disengageing completely.....and this morning i tried seven times to get it into reverse and it would not go at all
SNAKE
Old 08-27-2008, 12:05 PM   #4 (permalink)
82_320i's Avatar
yes to the floor mats
SNAKE
Old 08-27-2008, 12:11 PM   #5 (permalink)
If they go under the clutch pedal remove them and try It could be that... also sounds like you might need a new Clutch master cylinder or slave cylinder....pump the clutch up and down a shit load fast then try it... if it helps it is a hydrolic issue...
Old 08-27-2008, 01:24 PM   #6 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
sounds more like the synchros going out...what kind of trans fluid are you running?...i suggest replacing it with redline, should help free it up some more
being an E21 im assuming its a mechanical clutch not hydraulic right?
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 08-27-2008, 06:17 PM   #7 (permalink)
82_320i's Avatar
its not the clutch master cylinder because its a mechanical clutch.....no its not the floor mats in the way...the clutch goes all the way to the floor.
im not sure wut kind of fluid though. i bought it from a guy who only drove it like once a month for the past five years.
where can i buy redline? autozone?
SNAKE
Old 08-27-2008, 11:47 PM   #8 (permalink)
Red face
AHHH sorry thought it was Hydro... e21's are new to me i thought they where more like e30's.... where does the clutch engage? low? high? I dont know if there is an adjustment for it maybe bring the release point up a bit... and yes Redline does wonders My e30 use to grind into second and changed it and no more grind...
Old 08-28-2008, 12:51 AM   #9 (permalink)
gotKRAUT's Avatar
redline is usually found at most performance auto shops...i know car quest carries it, and a few local hot rod shops
lil redline MT90 works wonders
Kyle Sutherland
1995 BMW 540i/6:
Old 08-28-2008, 12:25 PM   #10 (permalink)
82_320i's Avatar
ok cool thanks.
are there any other pretty good brands? my clutch dis/engages for first and reverse all the way to the floor but while im driving it varies.
SNAKE
wut color MiguelACA Picture Showroom 22 06-30-2006 08:47 PM
My cluth pedal is tilted to the left... KingScare M-Series (M1, M3, M5, M6) 6 11-28-2003 01:33 AM
Wut to do...86 325i BMXicanbeamer 3-Series (E21, E30) 2 10-02-2003 03:42 PM
Wut to do...86 325i mishka411 M-Series (M1, M3, M5, M6) 0 12-31-1969 07:00 PM
