Clutch Slave Cylinder - BMW Forum - BimmerWerkz.com
Old 12-13-2007, 11:14 AM   #1 (permalink)
flipsgonetopless's Avatar
Car: 1991 318is
flipsgonetopless is an unknown quantity at this point
Send a message via MSN to flipsgonetopless
First of all I wanted to say thank for any help I can get.
I had a leak on my slave cylinder so it was replaced however now ther is still no pressure on my system even after I refilled the reservior with fluid. Do I still have to bleed the system or is there something I'm forgetting or something I'm missing? I'm confused... please help with any suggestions.
flipsgonetopless is offline   Reply With Quote
Old 12-13-2007, 03:55 PM   #2 (permalink)
elsabor67's Avatar
Car: '09 135i ///M Sport Pkg
elsabor67 is on a distinguished road
Send a message via MSN to elsabor67
If I remember correctly, yes you have to bleed the system. Good Luck.
How do I spell relief?!?!?!
NO MORE DAMN SNOW!!!!!!
elsabor67 is offline   Reply With Quote
Old 12-13-2007, 09:41 PM   #3 (permalink)
chinonca's Avatar
chinonca is on a distinguished road
If you replaced the slave the best way to bleed the system is open the bleeder valve on the slave and leave the reservoir open and let the fluid gravity bleed itself (wait till fluid starts dripping from slave) then start the pressure bleeding procedure.At this point you should have some kind of pedal pressure. Then just pump the cluthch and hold down then open bleeder valve. Repeat these steps a few times untill you achieve the right clutch pedal pressure> And thats all there is to it!!!
chinonca is offline   Reply With Quote
Clutch Slave Cylinder Bom356 3-Series (E21, E30) 7 02-13-2008 01:19 PM
clutch slave cylinder? jfertita 3-Series (E21, E30) 2 02-28-2007 07:07 PM
New Poster -- QUICK HELP! E36 Clutch slave cylinder question Michael Yount 3-Series (E36) 7 01-24-2006 03:31 PM
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Slave Cylinder Bleeding Help BmWNoobie 3-Series (E21, E30) 5 12-13-2003 07:32 PM
