Clutch Master Cylinder Replacement - BMW Forum - BimmerWerkz.com
Old 05-17-2005, 03:50 PM   #1 (permalink)
Cook911411 is an unknown quantity at this point
Hi all,
I am new to the Forum and my girl friend has an 87 BMW 325e.
It is in ok condition.
I recently replaced the slave cylinder per awful leak.
The M/C just started squeaking very bad when pressed and depressed and hte pedal feels sticky. I know this is the M/C.
Any tips on replacement?
Thanks,
Chris
87 BMW 325E
74 VW Bus
Chris
87 BMW 325E
74 VW Bus
Cook911411 is offline   Reply With Quote
Old 05-17-2005, 08:16 PM   #2 (permalink)
jze325i's Avatar
jze325i is an unknown quantity at this point
Originally posted by Cook911411@May 17 2005, 04:50 PM
Hi all,
Thanks,
Chris
87 BMW 325E
74 VW Bus
[snapback]345307[/snapback]
It definately sounds like a master cylinder.. I had an '88 super ETA 528 and I had a very similar problem, once I replaced the slave the master started to act up, was not to bad of a procedure, this was about 5 years ago, if I recall right the master feeds from the reservoir... If that is the case be careful not to create any air leaks, etc...
Good luck!
jze325i is offline   Reply With Quote
Old 05-20-2005, 05:41 AM   #3 (permalink)
I away recommend that both cylinders are replaced at the same time whenever the slave the master will blow shortly after. It’s not too bad to renew buy a new plastic union for the feed hose fitting as they snap and note the height of the pedals before you start as the 17mm bolt at the top of the cylinder is an adjuster if you replaced the slave you’ll know how to bleed the system
Clutch Master Cylinder Probs Help Cook911411 3-Series (E21, E30) 1 05-24-2005 11:22 AM
clutch master cylinder 300k 325e 3-Series (E21, E30) 7 05-27-2004 12:32 AM
330i Clutch Master Cylinder jaavaajoe 3-Series (E46, E90) 2 02-11-2004 06:59 PM
clutch master cylinder 635csiluver 3-Series (E36) 4 09-14-2003 04:49 PM
