| my clutch was even before quite loose but not as much as now. it does not engage until maybe half way through and then the pedal gets stuck there, so to put it back to regular position you have to pull it with your foot from the back. i was wondering whether this is just loose cable or what to check first. the clutch works fine even like that but it is quite bothering.
also, since this thing happened, in the morning when the car is cold, i usually go uphill and it seems like the clutch does not engage properly the first maybe 2 minutes, the car is a little jumpy in 1st 2nd and sometimes 3rd gear.
does anyone know what to look for??
thanks
__________________ <span style='font-size:13pt;line-height:100%'><span style='font-family:Arial'>'87 325i Convertible</span></span> |
