Clutch Adjustment - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 07-01-2004, 03:37 PM Thread Starter
dubes1982bmw320i is an unknown quantity at this point
Send a message via AIM to dubes1982bmw320i
Unhappy
[FONT=Arial][SIZE=7] i have a 1983 320I and it has a clutch problem. When the clutch is released the clutch seems to let go to early. I was wondering IF ANYONE knows how to adjust it?
dubes1982bmw320i is offline
post #2 of 3 (permalink) Old 07-01-2004, 07:53 PM
BMWJNKY's Avatar
BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute
It can't be adjusted, it is a hydrolic system. One of 3 things is wrong with your clutch system.
1. Clutch is worn and needs replacement.
2. Clutch master cylinder has started to go bad and needs to be replaced
3. Clutch slave cylinder has started to go bad and needs to be replaced
BMWJNKY is offline
post #3 of 3 (permalink) Old 07-01-2004, 08:36 PM
ronskal is an unknown quantity at this point
AJ's correct, I would say clutch master and slave cylinder. Replace them together. Not a hard job for the home mech.
Parts are reasonable at bavauto.com.
You can try bleeding the slave cylinder, but it may not help.
When a clutch is worn out, it will engage at the very end of pedal travel, late not early. It will also be harder to get a smooth release, like a light switch turning on instead of turning on a light dimmer switch smoothly.
02 GMC Yukon SLT 5.3
02 Ninja ZX9R
ronskal is offline
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 06:22 PM
Clutch Kevin325i 3-Series (E36) 13 08-06-2004 01:09 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 08:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 02:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 02:14 AM
