Check Light - BMW Forum - BimmerWerkz.com
Old 02-26-2005, 09:00 PM   #1 (permalink)
sweetlilbug's Avatar
Car: 1990 BMW 325i
sweetlilbug is an unknown quantity at this point
Send a message via AIM to sweetlilbug Send a message via Yahoo to sweetlilbug
Thumbs up
Why is this dumb light flashing all the time? used
<span style='font-family:Geneva'><span style='font-size:14pt;line-height:100%'><span style='color:green'>Drive or tow a BMW.........Nuff said!!!!</span></span></span>
sweetlilbug is offline   Reply With Quote
Old 02-26-2005, 09:16 PM   #2 (permalink)
CiscoKid's Avatar
does your OBC work?
Old 02-26-2005, 09:53 PM   #3 (permalink)
Does it stop if you push the check button on the over head (behind the rear view mirror) console?
Old 02-27-2005, 10:41 AM   #4 (permalink)
Car: 1990 BMW 325i
[snapback]300073[/snapback]
Maybe it's flashing because the washer fluid pump is not installed......could that be it? The only light that is on is the Washer Fluid light. I had to buy a new washer fluid pump since the previous owner was a tard and stuffed a screw into the hole of the washer pump and took the hose off.
Old 02-27-2005, 10:46 AM   #5 (permalink)
did you install the new pump and fill it up and the light is still on?
Old 02-27-2005, 12:53 PM   #6 (permalink)
Car: 1990 BMW 325i
[snapback]300330[/snapback]
Get the new washer pump tomorrow.
How the flip do i get the oil serviced light to go out since I just changed the oil? used
Old 02-27-2005, 01:39 PM   #7 (permalink)
youll have to get someone to do it, there is a tool, they might show you the way to do it yourself while you are there
Old 02-27-2005, 02:18 PM   #8 (permalink)
Fuggly is an unknown quantity at this point
Send a message via AIM to Fuggly
[snapback]300392[/snapback]
No special tools are required. All you need is a paper clip or a short piece of wire. http://www.bmwe30.net/cgi-bin/datacgi/data...0042&Section=02
Fuggly is offline   Reply With Quote
Old 02-27-2005, 03:06 PM   #9 (permalink)
leejgray is an unknown quantity at this point
Check out this site for you check engine light....
http://www.peakeresearch.com/index.html
leejgray is offline   Reply With Quote
Old 02-27-2005, 03:07 PM   #10 (permalink)
Oil Light reset....
Old 02-27-2005, 04:10 PM   #11 (permalink)
i know there is a way you can do it yourself, i just didnt have a link and didnt feel like explaining it
Check engine light Necktie 3-Series (E46, E90) 3 06-26-2004 01:54 PM
Warning! Cashier's Check Fraud L337E46 Classifieds Sell & Buy 2 03-06-2004 03:04 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
