Help! anybody out there know the steps to change the oil pan on a 325 IC?
I am using a "Bently's" and got the pan loose but cannot understand how to get to to the oil pump retaining bolts that are supposed to be removed befor the pan can come out. The pan does not drop far at the point I have gotted to......according to the Bently's .. I am now supposed to remove three pump retaining bolts, lower the pump into the pan and then I should be able to remove the pan......
ghead
