Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 07-27-2005, 04:24 PM   #1 (permalink)
Photos: 0
Tadao is an unknown quantity at this point
Hello. I changed my Transmission fluid in the winter and as the Bentley suggested I used 80/90 GL4 transmission fluid. As soon as it was changed I noticed that it was harder to get into 2nd gear especially in cold weather. Once the car is warmed up the shifting is fine. I figure this shouldn't be happening since I used the fluid Bentley suggested. Any ideas what could be wrong???
Thanks,
Mark
Mark
1984 325e
Tadao is offline   Reply With Quote
Old 07-27-2005, 04:45 PM   #2 (permalink)
Photos: 0
What year and model, there are three different fluids depending on model and transmission.
Old 07-27-2005, 05:11 PM   #3 (permalink)
Photos: 0
[snapback]365528[/snapback]
Sorry I should've said. It's an '84 325e
Thanks for the reply.
Mark
Mark
1984 325e
Old 07-27-2005, 07:13 PM   #4 (permalink)
Bmw1990's Avatar
Photos: 0
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
Too little, or too much fluid can cause erratic shifting.
I have also never heard of the fluid you used. I thought you just used dextron II or III depending on the model
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline   Reply With Quote
Old 07-27-2005, 08:43 PM   #5 (permalink)
Photos: 0
Scotsman is an unknown quantity at this point
dextron II and III are for automatic tranny's no? 80/90 gear oil are for standard trans and also diff in some cases. sorry though, my manuals only cover 89 - 93.
Scotsman is offline   Reply With Quote
Old 07-27-2005, 11:12 PM   #6 (permalink)
Bmw1990's Avatar
Photos: 0
You are probably right...my bad. Yea make sure you have the right amount of fluid.
Old 07-28-2005, 01:50 PM   #7 (permalink)
WoW killed my social life
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
[snapback]365613[/snapback]
as a general rule, always use ATF fluid in manual BMW transmissions. If you have a getrag 260 or 265 I know you are supposed to use ATF fluid.
When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko
Old 07-28-2005, 02:29 PM   #8 (permalink)
Photos: 0
Originally posted by Tadao+Jul 27 2005, 03:11 PM--><div class='quotetop'>QUOTE(Tadao @ Jul 27 2005, 03:11 PM)</div><div class='quotemain'><!--QuoteBegin-Bear@Jul 27 2005, 02:45 PM
Mark
[snapback]365541[/snapback]
[/b][/quote]
Here is what my service manual says:reference manual transmission fluid change:
1. Red label=DEXRON II
2. Green Label=Synthetic Gear Oil
3. No Label=API-GL-4 SAE 80- NON HYPOID GEAR LUBE OR SINGLE GRADE API SE OR SF HD ENGINE OIL
Old 07-28-2005, 04:39 PM   #9 (permalink)
Photos: 0
Ok. I think I have a green label. I'll have to check. I have the non-hypoid 80/90 gear oil in there. Maybe I should go synthetic then. Is it doing major damage now if I have the wrong one in there? Does it need to be flushed or treated if I change it out?
Mark
Mark
1984 325e
Old 07-28-2005, 07:12 PM   #10 (permalink)
Photos: 0
I do not suspect long term damage. If you have the wrong fluid, just drain and refill with the correct stuff.
Old 07-31-2005, 12:30 PM   #11 (permalink)
Angelic0-'s Avatar
Photos: 0
Angelic0- is an unknown quantity at this point
Send a message via MSN to Angelic0-
LSA oil (usually used on Limited Slips) or ATF fluid will serve you right since it will make shifting easier
| BMW E36 325i | BMW E34 520i | BMW E39 "M5" | BMW E60 530d MAPPED | BMW E38 740iA | BMW E32 750iAL |
Originally Posted by Mazi!
Viktor :|
Angelic0- is offline   Reply With Quote
Old 07-31-2005, 04:13 PM   #12 (permalink)
Photos: 0
M-technik-3 is an unknown quantity at this point
Originally posted by nukeduster+Jul 28 2005, 11:50 AM--><div class='quotetop'>QUOTE(nukeduster @ Jul 28 2005, 11:50 AM)</div><div class='quotemain'><!--QuoteBegin-Bmw1990@Jul 27 2005, 07:12 PM
You are probably right...my bad.* Yea make sure you have the right amount of fluid.
[snapback]365722[/snapback]
[/b][/quote]
What are you sniffing? ATF? That's for the power steering box and the automatic transmission. Please consult the manual before writing something like that.
M-technik-3 is offline   Reply With Quote
Old 08-02-2005, 12:17 PM   #13 (permalink)
Idle Member
E30crazy's Avatar
Car: 1984 325e
Photos: 0
E30crazy is on a distinguished road
Originally posted by M-technik-3+Jul 31 2005, 02:13 PM--><div class='quotetop'>QUOTE(M-technik-3 @ Jul 31 2005, 02:13 PM)</div><div class='quotemain'>
[snapback]366412[/snapback]
[/b][/quote]
He is right, especially in areas with cold weather it is recommended that you use ATF in your manual transmision. Gear oil is too thick and will not allow you to shift your transmission in cold weather. The previous owner of my car was a tech a BMW dealership and put ATF in the manual tranny. We use it in the tranny on both our e30's.
E30crazy is offline   Reply With Quote
Old 08-05-2005, 05:49 PM   #14 (permalink)
Angelic0-'s Avatar
Photos: 0
ATF - OR - LSA oil
they are both as thin
We use ATF on all gearboxes here in iceland due to cold weather..
Viktor :|
vB code is On
Tranny Fluid Level Check Beanster 3-Series (E36) 3 05-31-2005 10:12 PM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 10:12 PM
When to change "lifetime" tranny fluid LloydM 3-Series (E36) 9 08-31-2004 04:38 PM
manual tranny fluid nycbmw325is Bimmer Talk/Motorsports Talk 1 08-09-2004 05:16 PM
Just changed my own tranny fluid Autotechnica 3-Series (E36) 7 04-30-2004 10:15 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
