Center Bearing Problem - BMW Forum - BimmerWerkz.com
Old 08-07-2006, 01:39 PM   #1 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
I have an 86 325es, with an 89 325i 5 speed / driveshaft / center bearing. The center bearing from the 89 325i is a little bit smaller (where it mounts to the floor) so i drilled some new holes and threaded them. Worked for a little while, now the center bearing broke.
Should I get a center bearing thats made to fit on the 325es? And will it work on the 325i driveshaft?
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 08-07-2006, 06:13 PM   #2 (permalink)
Car: Opening soon:
In a pinch I solved this by bolting the center bearing bracket to a flat metal bar then bolt it in to the body. If you have a welder, weld a pice of flat steel to both ends then drill the holes.
Old 08-07-2006, 07:37 PM   #3 (permalink)
JoeMadoo's Avatar
Thats a good idea... I'm getting a new one right now, I was curious if i could get the size that acutally fits my 325es but still work with the 325i driveshaft...
Old 08-07-2006, 07:51 PM   #4 (permalink)
Car: Opening soon:
The only other option that worked was to remove the bearing from the rubber dampener and swap it out in the "es" carrier. This takes some care so you don't rip the rubber dampener. This worked 2 out of 3 times, it depends on the carrier's manufacturer.
Old 08-07-2006, 07:58 PM   #5 (permalink)
JoeMadoo's Avatar
OK so the ES and IS Driveshafts are different? So what would be easier, get an ES center bearing and swap the acutal bearing, or get an IS center bearing and rig the mounting.
Old 08-07-2006, 08:17 PM   #6 (permalink)
Car: Opening soon:
Depends on the build date.
Old 08-07-2006, 08:43 PM   #7 (permalink)
JoeMadoo's Avatar
For which? Mine was built prior to 4/1986...
Old 08-07-2006, 09:12 PM   #8 (permalink)
Car: Opening soon:
Actually, now that I think about it, I can't remember trying it... I swapped them out because they felt loose... Let me double check that.
Old 08-08-2006, 12:04 AM   #9 (permalink)
JoeMadoo's Avatar
All i need to know is if the driveshafts are the same with a 1/1986 325es and a 1989 325i.
Old 08-08-2006, 05:09 PM   #10 (permalink)
Car: Opening soon:
No, that actually depends on the flex disk size.
Old 08-08-2006, 07:23 PM   #11 (permalink)
JoeMadoo's Avatar
Oh ok, well i just orded one for an 325es. Is it hard to install these guys?
Old 08-08-2006, 07:28 PM   #12 (permalink)
Car: Opening soon:
Getting it out is the hardest part, pull the shaft apart, take out the C-clip, tap off the old bearing. Rest the shaft on a pice of wood as not to damage the splines.
Old 08-08-2006, 07:35 PM   #13 (permalink)
JoeMadoo's Avatar
Can you explain how to tap it off? I'm a center bearing virgin... I already have the drive shaft out, and the circlip off.
Old 08-08-2006, 09:02 PM   #14 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
You need a good drift or punch. Just take the two shafts apart and put the splined end against a piece of hard wood. This will give you access to the front side of the bearing. Use your drift and a good ball peen hammer to evenly distribute firm solid taps all around the bearing cage untill it starts to slide off. Be sure not to get it wedged by driving one side more than another!
DIRTE30 is offline   Reply With Quote
Old 08-08-2006, 09:06 PM   #15 (permalink)
Car: Opening soon:
P.S. To make it a tad easier, pull, cut or rip off the rubber/sheet metal houseing to expose the bearing.
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
E34 trans prog problem exacerbated electronblue 5-Series (E12,E28, E34, E39, E60) 5 03-02-2006 10:07 PM
Where to buy Center bearing Slow325i 3-Series (E21, E30) 4 11-06-2005 01:22 AM
center bearing precision tuner 3-Series (E21, E30) 2 12-31-2003 02:09 AM
