| Early systems (Motronic 1.1 only, I think) flash the fault codes automatically. If the check engine light comes on, leave the key in the On position, but dont start the car. The check engine light will begin to flash the code after about 3 seconds. Each flash is separated by about 1 second. There arent many codes on this system
1 flash......Air flow sensor malfunction.
2 flashes....Oxygen sensor malfunction.
3 flashes....Coolant Temp. malfunction.
4 flashes....Throttle switch malfunction. |
