Ok, so i just recently recharged my a/c and when its on and its really hot out for some reason, whenever i push in the clutch to slow down the engine stalls, but it only happens with the airconditioning on..can someone tell me why?
Somebody wasn't paying very much attention! He he he.... Help the little guy Starmavin. I'm guessing something to do with the fast idle switch or relay. Don't know what the little secret is tha Starmavin is getting at though, so listen up for the real dirt on the issue!
First, pull out your intake boot, and then unplug the throttle position switch. You'll see three prongs, with a multi-meter test for continuity between the left one and the middle. If there isn't you'll have to remove the throttle body to adjust or remove it. More on that after you get back.
If there is continuity, then remove the top panel above the glove box, just behind the computer to the left you'll see a green box, about the size of a bar of soap. This is your idle control module. check the plug for dirty contacts, if all is good you may just have to replace it.
P.S. If the one you are buying from the junk yard cam out of an 86/87 model check for a strip of green tape on the bottom, a defect prompted a recall from a broken solder point, the green tape marks the ones the recall was done on.
The throttle switch sends a signal to the idle control unit to raise the idle to compensate for the extra load. (A/C compressors suck out about 5-10 hp when on) If you have a lack of freon the compressor won't come on.
Unless of course your A/C compressor is no good and maybe locked up, that could stall out your motor easy. When the motor is off and cool reach down to the A/C and see if you can turn the front part of the compressor just in front of where the belt is.
