Can't Feel Clutch When Pushed? Urgent Help!! - BMW Forum - BimmerWerkz.com
Old 07-09-2005, 07:05 PM   #1 (permalink)
Privateye is an unknown quantity at this point
I have a 1987 E30 and i have just experienced a problem. I have removed my instrument cluster and the plugs attached to the back of it. I have strated the car since then and it worked fine. Today, i was about to start the car and i pushed the clutch and i could not feel anything. I checked the spring holding the pedal and it seems fine. Any idea why this could be happening?
Thanks in advance
Privateye is offline   Reply With Quote
Old 07-10-2005, 03:26 AM   #2 (permalink)
Angelic0-'s Avatar
Angelic0- is an unknown quantity at this point
Send a message via MSN to Angelic0-
Check if you have enough fluid and if you do, your clutch pump is out
| BMW E36 325i | BMW E34 520i | BMW E39 "M5" | BMW E60 530d MAPPED | BMW E38 740iA | BMW E32 750iAL |
Originally Posted by Mazi!
Viktor :|
Angelic0- is offline   Reply With Quote
Old 07-10-2005, 08:52 AM   #3 (permalink)
Yes, I would suspect the hydraulic clutch cylinder is kaput (about $35-$40). Can you still shift her?
Old 07-10-2005, 09:13 AM   #4 (permalink)
I can only put the car in gear once it is switched off. If it is on, it will make a cranking sound when it try to put in gear and it will not go.
Old 07-10-2005, 08:33 PM   #5 (permalink)
Angelic0-'s Avatar
Then you can be asure it's the clutch cylinder... no worries though should be easy to fix, it's easy in Mitsubishi's Colt 92' and shouldn't be any more complicated on a E30
Viktor :|
Old 07-11-2005, 03:57 AM   #6 (permalink)
Where is the clutch cylinder located on the E30?
Old 07-11-2005, 10:22 AM   #7 (permalink)
Haven't done a E30, did a TR-7, but if you follow the hydraulic line from the clutch pedal master cylinder to the transmission you should find the hydraulic clutch cylinder near the clutch and along side the transmission. There will be a hydraulic line, a bleed port with rubber cap, and two bolts that retain the cylinder. The procedure is to unscrew the hydraulic line, remove cylinder, install new cyliner, hook up hydrauulic line and then bleed the cylinder (just like you do brakes except you are depressing the clutch pedal as someone opens the hydraulic cylinder bleed port.)
Clutch Has No Resistance...need Help!! SDSUe36 3-Series (E36) 16 04-06-2011 01:48 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
