Can I put coil spacers in lowered springs - BMW Forum - BimmerWerkz.com
Old 10-09-2007, 02:10 PM   #1 (permalink)
325ESMAG is on a distinguished road
I bought a 86 325es and it was lowered, at first it was ok but the first time I cracked the oil pan it was the last time I wanted that to happen I fix the crack once twice three times and I got to fix it again. The oil pan is only 4 inches off the ground and its the lowest hang part of the car to. The springs are eibach and the shocks are blisten. The guy said it was kit. But what I want to know is can I put spacers in the front and rear springs to lift it.
325ESMAG is offline   Reply With Quote
Old 10-09-2007, 02:29 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
why dont you sell the springs to some one for cash + their old ones or cash and buy new ones that are stock or just below. i had my old e30 lowered and cracked my old pan once on friends drive way. i can see if i can find my old ones from my old 86 325es if your kinda local you can pick them up if i can find them i dont need them im in the bay area in CA
1992 318i Coupe parts car
I am Captain Obvious
Old 10-09-2007, 02:44 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Just get a factory or 666 Fabrication skidplate.
My M50 Powered E30 Page
Old 10-09-2007, 02:50 PM   #4 (permalink)
do they make any thing for e38's?
Old 10-09-2007, 03:00 PM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
I didn't see any factory opitions after looking in ETK but 666 Fab might be able to do something for you. Why do you need one for an E38?
Old 10-10-2007, 02:07 PM   #6 (permalink)
my sister iable driv and i see her some how hitting it
Old 10-10-2007, 02:14 PM   #7 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Old 10-10-2007, 02:51 PM   #8 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
my thoughts exactly ^^ , someone had a few too many drinks
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 10-11-2007, 12:17 PM   #9 (permalink)
Do you think the shocks are long enough because it was a kit that everything came in and I don't want to put longer springs in and the shocks are not the right length
Old 10-11-2007, 12:59 PM   #10 (permalink)
gotKRAUT's Avatar
what brand shocks are they? unless they are bilstein sports, or Ground Control/TC Kline Koni's they will be long enough
Edit: NM i just read they are bilsteins...you should be fine anyway...wont hurt anything...they will just have more preload than before...
btw, how do you bottom out the oil pan? im lowered 2" and i have NO problems...
Kyle Sutherland
1995 BMW 540i/6:
Old 10-11-2007, 06:49 PM   #11 (permalink)
how local are you to palo alto, CA b/c you can have my old springs.
Old 10-12-2007, 11:09 AM   #12 (permalink)
My mistake my car's oil pan is about 3 inches off the ground because i have to squeeze my fist under it. The other day I was going to push a 2000 ford taurus and guess what my car is so low that i actually went under the back bumper so couldn't do it.
....so new coil springs coming :) topless_328 3-Series (E36) 12 04-02-2007 10:03 PM
Will shocks/struts coil springs and sway bars from 98 M3 fit on my 89 325i Slow325i 3-Series (E21, E30) 0 11-15-2005 08:09 PM
Ar E36 Coil Springs The Same In All Models? Shudogg 3-Series (E36) 8 03-25-2005 11:30 PM
Difference: Coil Springs Vs. Coil-over Springs? funtoos 3-Series (E36) 3 02-26-2005 11:46 PM
Wheel Bearings Sound (lowered X Cut Springs) idanity 3-Series (E21, E30) 0 12-12-2004 09:37 AM
