Cam worth it. - BMW Forum - BimmerWerkz.com
Old 09-02-2004, 08:47 PM   #1 (permalink)
dubes1982bmw320i is an unknown quantity at this point
Send a message via AIM to dubes1982bmw320i
I was looking to get a new cam to upgrade my 320i. But it the performance upgrade really worht the money?
dubes1982bmw320i is offline   Reply With Quote
Old 09-02-2004, 10:33 PM   #2 (permalink)
I think it depends on whether your gonna change the engine management to the new cam. But I believe in leaving BMWs stock
Old 09-02-2004, 11:27 PM   #3 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
not really unless you go forced induction or new pistons.
Fox is offline   Reply With Quote
Old 09-02-2004, 11:50 PM   #4 (permalink)
joshh is an unknown quantity at this point
Unfortunately you cant just change the cams and have lots more power. The motor works as a unit. Every part must match every other part to function its best. So throughing cams in there is not going to work. You may get some good power out of it if you match up all the parts. I.E. is the Intake manifold going to have the right runner lengths, will the plenum on the intake manifold be the right size to support the new cams, do you need new spings for the cams....it goes on for miles. Theres no sense in spending the money and not getting all you can out of it. Plus dyno tuning is something I would never do without when building a "built" motor.
Finally pulled the M50 from the donor car.
joshh is offline   Reply With Quote
Old 09-03-2004, 06:34 AM   #5 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
i suggest a cam if you have intake exhaust headers basically everything and you are looking for that final bolt on to finally open EVERYTHING up...i just helped my buddy throw in a cam on his 325i that already had intake headers exhaust JC Chip MAF conversion 40% lockup 4.10 LSD MSD ignition and throttle body...on dyno before and after there was a 21 HP difference after the cam swap...so my advice is do every bolt on first then cam...and dont do the cam unless you plan to rebuild the head at the same time....no point putting in a new cam with stock head internals...upgrade the valve springs valves 3 angle valve(5 angle is pointless...dyno proven unless you are running forced induction) ETC
ohh and fox by the way there are several different types of cams designed for Non Modified, mild tuned NA, Highly Tuned NA, and Mild and Highly Tuned Forced induction.....though im sure you knew that :P
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-03-2004, 02:25 PM   #6 (permalink)
Fox
Moderator
yea, and they are $600 and dont offer much. For $600 you can make a supercharger setup.
Old 09-03-2004, 07:03 PM   #7 (permalink)
schneider252's Avatar
most of u guys are all talk and no go imo
Old 09-03-2004, 07:57 PM   #8 (permalink)
So are you trying to say that you can just add a cam and get lots of power?? Then I know what file to put you under.... or
Or are you refering to something else?
Old 09-04-2004, 11:52 AM   #9 (permalink)
Halon is an unknown quantity at this point
Send a message via AIM to Halon Send a message via MSN to Halon Send a message via Yahoo to Halon
I've heard you should actually, if you're going to build your motor, get all the internal motor workings done first. If you want to increase displacement you need to get your engine bored first. "Start from the oil pan and work your way up.", otherwise you'll find yourself rebuying parts. :-/
Halon is offline   Reply With Quote
Old 09-05-2004, 03:18 AM   #10 (permalink)
gotKRAUT's Avatar
wow then my last 4 cars never existed lol...i always start with bolt ons and see if they add enough horsepower or if i need to bolt in a cam....and NO its not as easy as bolt it in...if you read my above post you will see that...lol but YES they do give you AWESOME power for the money...but they wont do anything unless you have alllll bolt ons done and you install it with higher rev valves and valve spring...you will experiance a longer smother power band and more HP all around..
Kyle Sutherland
1995 BMW 540i/6:
Old 09-05-2004, 12:33 PM   #11 (permalink)
I've actually heard that if you get appropriate valve springs, valves, rocker arms and rocker arm retainers, you could make the m10 rev to about 8 or 9 thousand rpms with appropriate fuel managment. I don't know if thats the engine in question anymore... but just sayin - thats my engine. It may not be the fastest engine in the world - but it does what I want it to do. and thats nice. Gotta beef up my suspension next - I'm starting at the bushings and then working my way out. :P
Worth it? Enthuziast Picture Showroom 0 10-15-2005 04:40 PM
Are cross drilled rotors worth it...? Charleston Chu 3-Series (E21, E30) 10 10-14-2005 10:03 PM
Cam belt Timmo 3-Series (E21, E30) 2 10-04-2005 03:08 PM
Is All The Money Worth It? bpb05 3-Series (E36) 9 08-04-2005 06:33 PM
list yo mods!! leftone 3-Series (E46, E90) 7 05-19-2004 02:52 PM
