Cam belt - BMW Forum - BimmerWerkz.com
Old 10-03-2005, 06:06 AM   #1 (permalink)
Timmo is an unknown quantity at this point
Unhappy Cam belt
Hi out there, Iv got a standard 325 sub assembly with a worked 323 head to match the block. which cam belt do i have to use the 325 or 323 belt?
Would the 323 CPU work with the 325 engine or do i have to upgrade that as well.
Any advice is appreciated.
E30 1984 2-door 323
Timmo is offline   Reply With Quote
Old 10-04-2005, 02:50 PM   #2 (permalink)
DJProfessor's Avatar
DJProfessor is an unknown quantity at this point
you can use the 325 belt if i am not mistaken, but if you are using the 323 head are you using the 323 engine management system as well? if you are then you need the 323 brain.
sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
DJProfessor is offline   Reply With Quote
Old 10-04-2005, 03:08 PM   #3 (permalink)
e36_m3_Turbo's Avatar
cpu wont work....check realoem.com for part numbers
No longer red.
used 528: rear window & cam belt question jcmky 5-Series (E12,E28, E34, E39, E60) 1 10-16-2005 04:37 PM
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 03:44 PM
Broken Timing Belt?? jaymz 3-Series (E21, E30) 12 10-17-2004 08:22 PM
Passenger Side Seat Belt Install YoungExec728 3-Series (E36) 1 10-13-2004 12:34 AM
Replacing Alternator/Fan Belt chardotcom 3-Series (E36) 1 12-05-2003 08:18 AM
