Broken Timing belt, possible valve damage? - BMW Forum - BimmerWerkz.com
Old 04-14-2007, 11:15 AM   #1 (permalink)
tkcc100 is on a distinguished road
9/87 325 I 163,436 miles
Last winter on a really cold day I attempted to start this vehicle and it broke the timing belt.
The engine never started but it did turn over a number of times with the starter.
I am well aware of the fact that this is an interference engine but I have little actual experience around this particular engine. What's the consensus out there among those that have in fact worked on this engine.
Replace the belt and hope or pull the head?
I apologize if this is a redundant posting but I haven't been able to find a definitive answer.
Is it possible for the valve and engine to survive a broken belt or not?
If I replace the belt and the valve are in fact bent do I risk further engine damage?
Any and all assistance that you can offer will be greatly appreciated.
Thanks!
tkcc100 is offline   Reply With Quote
Old 04-14-2007, 01:24 PM   #2 (permalink)
Car: Opening soon:
If it broke while running or cranking, you have bent valves. You have zero chance that you didn't. The impact of the piston hitting the valve is very severe replace all rocker arms that are associated with any bent valves.
Old 04-14-2007, 10:30 PM   #3 (permalink)
Thanks Starmavin,
No good news but at least a definitive answer.
Guess I will start pulling the head tomorrow.
Old 04-18-2007, 11:55 AM   #4 (permalink)
I have come to the forum several time for information and have always been assisted, so I feel some sort of an obligation to do my part by closing this thread.
You were absolutely right. Even though the engine never started I have 6 bent valve, 6 broken rocker arms and it even broke the cylinder head casting in two places over the rocker arm shaft.
Conclusion: If your belt has broken and or slipped you have bent valves or as in my case an expensive boat anchor.
Advise: Change the timing belt as recommended. Evey 50 or 60,000 miles or 5 years which ever comes first. It is a bit of a pain to do but I can assure you it get worse.
Thanks!
timing belt jfertita 3-Series (E21, E30) 8 01-26-2007 03:52 PM
How to adjust Timing belt tension on 88 325ix Slow325i 3-Series (E21, E30) 1 07-22-2006 01:02 PM
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 03:44 PM
Broken Timing Belt?? jaymz 3-Series (E21, E30) 12 10-17-2004 08:22 PM
