Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 04-05-2005, 11:49 PM   #1 (permalink)
Photos: 0
ronpapworth is an unknown quantity at this point
1985 325e. Changed the fuel filter after a slight hesitation started about 2K-3.5K RPMS. Decided to hot soak it and while letting the seafom sit in th engine, decided to spray the Idle control valve out with carb cleaner. Bad I dea I guess because now I have the tell-tale idle flux from 900K to 1400K in a loop. I will do some testing on it tomorrow but would that have killed it or is there any resurrecting it?
Back to the hesitation. I will test the innner and out fuel pumps tomorrow and I see that a failed transfer pump or failing main pump can cause the hasitation too. I noticed to night that the main pump seems to buzz loudly on and off. I think I still hear it running constantly, just sounds like it is going ito overload intermittently. Sounds like a pump going out... Will any E30 transfer and main pump fit this 325? I think I see some that look like it but they say its for a 318i, which I would think was a different set of pumps...
Finally the AFM. I saw a post that said the hesitation could come from some dead spots in the potenmeter(sp?) in the meter. My question there is will any 3eo AFM work as well, meaning a 325i ro a 318 e30 AFM...
Thanks all.!
ronpapworth is offline   Reply With Quote
Old 04-06-2005, 12:36 AM   #2 (permalink)
Kowalski's Avatar
Photos: 0
Thanks all.!
[snapback]326375[/snapback]
as long as the numbers on the AFM are the same they should fit. however some also have different connections i know my 318 has a round connection to the MAF but the older 325's and maybe 318's? i have square ones.
264* roatation and 388 lift
vB code is On
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
