Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 10-24-2004, 10:29 AM   #1 (permalink)
Ben
Photos: 0
Ben is an unknown quantity at this point
Ok, my brother has a Uk spec E30 325i, 1985/6 model. Driving along and the engine suddenly cut out and will not restart.
First off, I've tried getting the error code from the ecu as suggested in the FAQ but can't get it working. Does it work for this model and if so can anyone tell me how quickly/at what interval to push the peadl down.
Secondly (biggie I know) any suggestions on things to check? We're both mechanically minded but I know nothing about BMWs and my brother doesn't do internet :P
Thanks,
Ben
Ben is offline   Reply With Quote
Old 10-24-2004, 04:29 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
If it suddenly died and didn't sputter before it died I would start with putting in a new main relay usually arround $20. If it sputtered then died it's probably fuel related, probably the pump in the tank took a dive.
My M50 Powered E30 Page
Old 10-25-2004, 02:13 PM   #3 (permalink)
Ben
Photos: 0
Sorry, that was a terrible post. I'll try and get some more details. Thanks for the suggestions tho, the main relay has been checked as have the engine sensors and they all appear to be working. The ecu has been tested and seems ok but is being retested. The fuel pump is not working when the ignition is switched on but works when a earth is bodged on to it. This was done by a mechanic who didn't think that was the problem as he still didn't know what was going on when he left. used
Cheers,
Ben
Old 10-25-2004, 06:16 PM   #4 (permalink)
Photos: 0
mr_fixit is an unknown quantity at this point
First (always) - determine if the problem is fuel or spark.
Fuel - spray a healthy shot of brake cleaner in the intake, close it up and crank it - if it fires for a few seconds - its a fuel problem.
Spark - pull off a spark plug lead - stick a small phillips head screwdriver in the plug cap and lay the screwdriver so that the metal shaft is 1/4" (1cm) from the head (not touching - just close enough to see a spark - like the spark plug gap) - have someone else crank it over for a few seconds - do you see a spark? (Don't run it like this - quick test only)
Fuel problems - most likely a fuel pump problem - test for 12 volts on the 30 pin of the fuel pump relay (if no, its the fuse). Next jumper the relay (87 to 30) - does the fuel pump run constantly? if yes the car should start bad relay. No most likely a bad fuel pump (unlikely to be a broken lead to the fuel pump)
No spark? Most likely a bad speed/position sensor (also called refernce sensor). This can be tested for resistance - but this will only tell you if its fried, not if its working correctly.
mr_fixit is offline   Reply With Quote
Old 10-26-2004, 12:04 PM   #5 (permalink)
Ben
Photos: 0
EDIT: It just died straight off, no spluttering etc, no warning.
It's a spark problem then, but the fuel pump also doesn't work
I'm guessing the reference sensors are also know as the TDC and RPM sensors? If so the TDC sensor was found faulty and replaced, don't think the RPM one was. We were told that apart from that the only other causes of no spark are faulty fuel/main relays does this sound right? All of the above has been checked and works...
Also, the fuel pump doesn't work but when the mechanic put a 12v feed to it's fuse the engine ran (pump working and sparks!) But he then poked something else and now that doesn't work again.
ghead ghead ghead ghead ghead
Cheers,
Ben
Old 10-28-2004, 07:54 PM   #6 (permalink)
CR320i's Avatar
Photos: 0
CR320i is an unknown quantity at this point
Send a message via MSN to CR320i Send a message via Yahoo to CR320i
Thanks,
Ben
[snapback]217299[/snapback]
check FUEL PUMP RELAY. HAPPENED TO ME.ON THE HIGHWAY. CAR TOWED TO THE MECHANIC WHO LAUGH :nana
E30
1985/320i
german version
CR320i is offline   Reply With Quote
Old 10-31-2004, 05:06 PM   #7 (permalink)
Ben
Photos: 0
The fuel pump relay has been checked and is working. We got the ECU back yesterday and that's passed 2 simulations now so should be fine.
We're now completely stumped and have checked everything down to the inhibitor switch on the auto gearbox.
Can we get a fault code (asuming there is one) from the ecu by pressing the gas pedal 5 times after turning the ignition on? If so roughly how long between presses?
Cheers,
Ben
Old 10-31-2004, 05:52 PM   #8 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
Have you tried installing new plug wires? The TDC sensor is part of the #1 plug wire and has been known to crack internaly with age. You can still get spark but it wornt run because the car won't know what cylinder to fire.
Old 10-31-2004, 11:52 PM   #9 (permalink)
Photos: 0
DIRTY E30 is an unknown quantity at this point
Cheers,
Ben
[snapback]221815[/snapback]
the same thing happened to me about 2 mounths ago, non face lift E30's fuel pumps are shit! i had a holden comodor pump put in mine get better pressure and is 3 times cheeper....
DIRTY E30 is offline   Reply With Quote
Old 11-01-2004, 12:24 AM   #10 (permalink)
Banned
xsperf's Avatar
Photos: 0
xsperf is an unknown quantity at this point
does it crank at all, and when it cranks, it just WONT start? no sputtering, .. and in that case, then u guys probably flooded the engine if fuel is coming in. did u check distribuator cap, or whatever that kind of BMW uses? the coils maybe
xsperf is offline   Reply With Quote
Old 11-01-2004, 12:34 PM   #11 (permalink)
Ben
Photos: 0
The engine cranks over but no response, no spluttering etc.
As mentioned above the fuel pump isn't running with the ignition in addition to a lack of spark so it's not flooding.
We're not getting any spark at all, could that still be the leads?
Cheers,
Ben
Old 11-01-2004, 01:22 PM   #12 (permalink)
Photos: 0
witeshark is just really nicewiteshark is just really nicewiteshark is just really nicewiteshark is just really nice
Is power getting to the distributer?
Old 11-01-2004, 02:56 PM   #13 (permalink)
Banned
xsperf's Avatar
Photos: 0
if u dont have a spark, thats ur problem.. lol. check ur wires, and check to see if ur spark plugs have oil on them,if they are corroded, or do they look just fine.
and the other thing is, did it idle rougth before that?
Old 11-02-2004, 09:38 AM   #14 (permalink)
Ben
Photos: 0
[snapback]222368[/snapback]
That's ok then. How much is a new spark from a main dealer...
Anyway... we've got no low tension feed to the coil so nothing after. There's continuity from pin 1 to the coil and the coil works fine on a donor car. Fuel is being fed when the engine cranks (my mistake!)
Idle was fine before, there were no intermittent faults or warning signs. I'm now told the engine died due to the crank position sensor failing which has been replaced.
Also does anyone know what pins 10, 28 & 29 do on the ecu?
I'm also told that it's an M3 automatic which apparently makes things more interesting! Cheers for the suggestions
Ben
Old 11-12-2004, 11:41 AM   #15 (permalink)
jze325i's Avatar
Photos: 0
jze325i is an unknown quantity at this point
I am having similar problem with my 1990 325i... It was more of a gradual problem though, would stall out from time to time and got progressively worse, thought it was fuel related so I replace fuel fileter and pressure regulator, still no fix.. Then I did the cap & rotor & plugs (needed them anyway..) still no fix.. Wires look ok visually.. Now the car is dead completely, all relays checked out ok, fuel pump runs, relay good, DME relay for the brain is good, so I am now going to put a spare coil in, if that does not fix then I am confident that it is the crank sensor.. Phew, that will be everything!!!
jze325i is offline   Reply With Quote
vB code is On
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 05:27 PM
Car Died, Starter Has Funky Sound javieruz 3-Series (E21, E30) 9 03-14-2005 10:22 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
