Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 01-31-2005, 03:35 PM   #1 (permalink)
Idle Member
Photos: 0
e30bmwes is an unknown quantity at this point
ok so my brakes are not working and im not sure why the problem is something with pressure caues there is no pressure on when i push on the brakes it feels like im pushing nothing and im pretty sure it is not the brake fluid
if you have any idea and can help me out then
thanx oo=[][]=00
Member of the: over 200,000 miles club
Member of the: 120mph in a 45mph club (beating 04 accord)
e30bmwes is offline   Reply With Quote
Old 01-31-2005, 06:48 PM   #2 (permalink)
Photos: 0
it would help to know the year and model and if you have found a puddle of brake fluid or not, if not then it could be your brake master cylinder, sometimes they leak inside of the brake booster and you wouldnt know that it was leaking
Old 01-31-2005, 08:10 PM   #3 (permalink)
Kowalski's Avatar
Photos: 0
[snapback]283463[/snapback]
check your pads, check your brake fluid leve. you also might have a cracked brake line, or air in your line. brake fluid doesn't compress where as air does, so if you have air in your line it would cause spongy brakes, and loss in braking power. so bleed your brakes, and then if none of those work, then check your master cylinder. and if your fuild is really low then you will have to bleed your brakes because air has most likley gotten into them with low fluid.
264* roatation and 388 lift
Old 02-18-2005, 07:04 PM   #4 (permalink)
Photos: 0
Putin is an unknown quantity at this point
I'm having a similar problem with my 81 323i. The car has been standing idle for about 2 months while I was abroad, it needed a jump start when I got home but was driving fine yesterday. Coming back from the supermarket today and the brakes gave up on me!
They work for about the first inch of movement then I lose pressure on the pedal. Like you say it feels like I'm not pressing on anything and the car does not slow. The only way I could stop it was by repeatedly pumping the first inch of the pedal.
The fluid resevoir is full, I havent seen any leaks. Would I get this behaviour from air in the lines? Surely that would just make it spongy with the brakes kicking in as the pedal reaches the floor?
Putin is offline   Reply With Quote
Old 02-18-2005, 08:46 PM   #5 (permalink)
guywithblack88e30's Avatar
Photos: 0
guywithblack88e30 is an unknown quantity at this point
sounds like master cylinder same exact thing happend on my 83 volvo turbo there completly different cars but it doesn't hurt to change it. i change it on that car easy on driverside against firewall where brake fluid goes
Member of got its raining(in Members Lounge) to 100, 237, 250, & 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 02-20-2005, 04:07 PM   #6 (permalink)
Photos: 0
Yeah, I've had a look around on other forums and that seems to be the consensus. It doesn't look to hard to change so I'll give it a shot. The vaccum servo looks pretty rusty and the brakes have always been hard to apply (only had the car 6 months) so I'll swap that while I'm at it. Thanks alot!
Now to phone BMW and see how much this is gonna hurt me
vB code is On
Brake Light Problem Chameech21 3-Series (E36) 4 01-11-2005 10:29 AM
1999 E39 Brake Problem MexiMule 5-Series (E12,E28, E34, E39, E60) 5 10-25-2004 12:27 PM
Weird Brake Problem '94 318is ultraviolet353 3-Series (E36) 5 10-19-2004 07:52 PM
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 04:39 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
