Brake Pad Virgin - BMW Forum - BimmerWerkz.com
Old 10-02-2006, 05:46 PM   #1 (permalink)
Neil Paz is on a distinguished road
Brake Pad Virgin
I replaced the front brake pads and the sensor today. The car even stops.
How do I know that there isn't air in the line or something like that, in other words, how do I know I did it right?
Neil Paz is offline   Reply With Quote
Old 10-02-2006, 06:26 PM   #2 (permalink)
Car: Opening soon:
Unless you opened the bleeder and let air draw back in, you are ok.
Just as a tip: You should never pry back the piston on an ABS car with out first opening the bleeder, doing so pushes old funky fluid into the ABS unit and often leads to it's early demise.
Old 10-03-2006, 01:16 PM   #3 (permalink)
Hi sorry I’ve been away for the summer, but I’ve started racing single seatrs (not BMWs.)
Technically you should never push any brake piston back without opening the bleed nipple. This put back pressure on the master cylinder. I’ve never known it to cause a problem on BM’s but it does hurt other make. As long as you close the nipple as before the fluid stop running out you have to bleed the brake.
Old 10-03-2006, 04:18 PM   #4 (permalink)
Thanks
No ABS on my `84 325e. It seems good.
I am having problems getting the rear guide pins out though. I tried using a 1/4" hex and I think its a little small. Maybe a 3/8" or a 7mm??
Old 10-11-2006, 01:38 PM   #5 (permalink)
it's 7mm Allen key
Brake pad wear sensor wire? da_bull 5-Series (E12,E28, E34, E39, E60) 11 09-19-2006 05:00 AM
Brake Pad Warning light craigf 3-Series (E36) 7 05-27-2006 11:07 AM
Brake pad reveiws, please!! Wonderboy 3-Series (E36) 36 05-18-2006 01:15 AM
brake pad light came on Andres823 3-Series (E46, E90) 9 12-20-2005 10:56 AM
