Brake master concern on a 1987 325i! - BMW Forum - BimmerWerkz.com
Old 08-05-2008, 05:20 PM   #1 (permalink)
RB200sx is on a distinguished road
Red face Brake master concern on a 1987 325i!
I'm working on a 1987 325i. The brake fluid is coming into the drivers floor. Not by gushes but it has the carpets some what wet with brake fluid. I began to replace the master because I thought that it was coming from behind the master at the rod. It was dry but I replaced it any way, it was a little old and the rubber seal didn't look too healthy. As I filled the reservoir the fluid didn't top off to the full mark but began coming out of a tube that was on the side of the reservoir a little bit over the midway line where the two halves of the reservoir are bonded. It has a hose that connects to it and goes behind the brake booster and into the fire wall slightly above where it bolts up. Sorry this is so long...
Any way, my question: Is it normal for the fluid to come out of this little port, or nozzle? I'm not sure that it is but I'de rather ask people with more experience with this model than I do. It's my neighbors car and I want to do a good job for him.
It's my first technical question and it was long. Sorry to be a pest.
RB200sx is offline   Reply With Quote
Old 08-05-2008, 07:50 PM   #2 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
clutch master cylinder...
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 08-05-2008, 08:29 PM   #3 (permalink)
Thank you very, very much. I'll look into it. It makes sense now.
Old 08-06-2008, 09:43 AM   #4 (permalink)
gotKRAUT's Avatar
no worries, i had mine go out about a year ago...fun job...lol
Kyle Sutherland
1995 BMW 540i/6:
Old 08-06-2008, 07:20 PM   #5 (permalink)
You are not kidding! This was my first time removing one of these and it was a nightmare. I'm no small dude. Fitting my body in the position that I needed to get to the bolts was an adventure.
I removed it and found that the hose that slips over the connector was chaffed. I purchased some fuel line to remedy the worn hose but I dout that fuel line is sufficient. I may have to go and buy a piece of hose at BMW dealer. That little sprng that keeps the tension on the pedal ate through it. Again, thanks a lot for the help. You didn't have to and that means a lot.
Old 08-07-2008, 09:23 AM   #6 (permalink)
I'm reinstalling the original clutch master with a new hose. Question: what did you do to keep the tensioner spring, right above the master, from maintaining pressure on top of it?
I'm a big guy at the shoulders and am having the time of my life, LOL, trying to do two things at a time. I don't fit completely in between the seat and the steering wheel to get both arms in to do what I need. And the space between the seat and the "A" pillar is just as bad for me. Do I reinstall the spring afterwards? It's tight and I wonder how much more work it is.
While typing I noticed I have a fresh cut on my hand... nice.
Old 08-07-2008, 12:17 PM   #7 (permalink)
Sorry to come back and sound like an idiot... I figured out how it goes and it was easier to reinstall the clutch master. Before I removed the master the tensioner spring was sitting on top of the hose that goes into the master. I saw that there was actually a spot with indentations right above the master where that spring actually sits. I'm relieved to have spotted that. I actually got the right position for that spring through another thread that I was looking at.
Even if no one responds I still get help! Cool! This site is chocked full of unintended info. And if it's intended, then, I praise this site as being number ONE! Thanks to every one that helped, intentionally and unintentionally!
Last edited by RB200sx; 08-07-2008 at 12:19 PM. Reason: Didn't like the smiley face and I didn't spell right.
Old 08-10-2008, 10:12 PM   #8 (permalink)
gotKRAUT's Avatar
sorry i forgot to follow up...im glad the vacuum pump trick worked out
Kyle Sutherland
1995 BMW 540i/6:
Brake Master Cylinder Rebuild Kit ? snpower 3-Series (E21, E30) 5 08-18-2006 02:46 AM
1987 325i Sedan bdogthehog OEM Parts 0 05-08-2005 10:47 PM
Faulty Brake Master Cylinder Cap... 2001BMW330iRob 3-Series (E46, E90) 2 09-28-2004 03:51 PM
Nice 528e but certain things concern me... 528eOwner 5-Series (E12,E28, E34, E39, E60) 4 04-10-2004 10:53 AM
Wont Idle after Brake Master Cylinder Replaced saeanddte 3-Series (E21, E30) 7 03-25-2004 06:56 AM
