"Brake Lining" Light Flashes - BMW Forum - BimmerWerkz.com
Old 09-03-2008, 09:34 AM   #1 (permalink)
325isBMW1988's Avatar
Car: 1998 328i
325isBMW1988 is on a distinguished road
Send a message via AIM to 325isBMW1988
I noticed it the other night when i was driving around. it seems like it only flickers when i hit bumps but it doesnt stay on. almost like something is irritating the sensor or something. Its just a quick couple of flashes then its off. Can anyone help me out? Last thing i want is my brakes to go
325isBMW1988 is offline   Reply With Quote
Old 09-03-2008, 09:46 AM   #2 (permalink)
W00T
Numark318i's Avatar
my e30 does the same thing. The Hawk HPS pads i purchased dont hold the sensor in place correctly, so i think it contacts the rotor under certain conditions.
So i guess if you took the front wheel, and brake caliper off you could prolly figure out a way to reattach the sensor correctly.
The light flickering doesnt necessarily mean the brakes are going to go, the sensor wont effect that. Just get a visual that your brakes still look like they are in good condition.
Old 09-03-2008, 11:47 AM   #3 (permalink)
Car: 1998 328i
Smile
Thanks! ive had VERY worn brake pads on my last car and my BMW def. has good brake pads. ill have it jacked up today so i might as well check out the pads and sensors while its up. Thanks again
Old 10-18-2008, 08:36 AM   #4 (permalink)
dark_islight's Avatar
dark_islight is an unknown quantity at this point
I had a similar problem. Flickering light was due to the sensor wire rubbing on the wheel rim, it had eaten throught the insulation on the wire causing the indication on the dash.
dark_islight is offline   Reply With Quote
Old 10-18-2008, 11:08 AM   #5 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
easy fix, just re connect the wires cover em with some shink tube and re route it properly to stay away from the wheel, hah
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 10-20-2008, 11:26 AM   #6 (permalink)
Crispy1st's Avatar
Car: 1987 BMW 325, YZF 750 yam
Crispy1st is on a distinguished road
My check brake lining light is on everytime I start the car, but there is nothing wrong with my brakes. I have learned to ignore it.
Crispy1st is offline   Reply With Quote
Old 10-23-2008, 06:18 PM   #7 (permalink)
hk30's Avatar
Car: 1991 325i
hk30 is on a distinguished road
mine stays on but my brakes are brand new!!! jus a bad sensor or something
KEEP IT P.I.
hk30 is offline   Reply With Quote
"check brake light circuit" on bmw 325is mickey428 3-Series (E21, E30) 4 02-04-2009 09:13 PM
"brake light circuit" golfgod41 3-Series (E36) 0 08-04-2008 11:31 AM
"Check Engine" Flashes on and Off Chaosbunny 3-Series (E36) 4 05-10-2006 08:03 AM
"brake Light Circuit" Message On Console GatorInSC 3-Series (E36) 6 10-29-2004 09:00 AM
